| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
Location: Where the world's best tea come from:Kericho Kenya
Hi guys,
I built this crossover and preamp using tl072.12dB/octave low pass crossover at 106Hz for the first opamp and a 24dB gain preamp for the second opamp.Now its working but...a slightly audible hum when the gain knob is halfway up,the hum disappear when the knob is all the way up or down.The woofer cone moves considerably when the knob is turned with no input signal.There's also a whining noise a few seconds after the power is switched off. Is there something i overlooked?I will appreciate your help in solving the problem. Regards.
if there are no sparks,it probably doesn't work! |
#2 |
I got it from esp projects.
I made the following changes: input r28:1k vr4:200k r19:12k bypassed c5&c6 and put a 10uf cap after the 100r r28.
#3 |
I used the crossover calculator to get the r&c values(not the showed values).I just realised my mistake:i used 2c instead of c.How does this affect the crossover?
| Help with mis-behaving Cambridge 540A | J Wiggle | Solid State | 10 | 29th April 2012 08:00 AM |
| LK-72 mis-wired or am I confused? | griff199 | Tubes / Valves | 7 | 27th March 2010 04:33 PM |
| Mis-behaving Cyrus II | gazbo83 | Solid State | 5 | 31st August 2009 06:28 AM |
| How much mis-match can an OT take? | bereanbill | Tubes / Valves | 6 | 10th May 2009 01:40 PM |
| LM337 behaving strange??? | deduikertjes | Power Supplies | 18 | 27th May 2006 07:40 AM |
| Page generated in 0.09088 seconds (53.67% PHP - 46.33% MySQL) with 11 queries |
