| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Found this today, looks interesting if it turns out to be real, it needs external opamps:
http://www.mas-oy.com/archive/da6116.pdf
When a measure becomes a target, it ceases to be a good measure. C.A.E. Goodhart |
#2 | |
The high signal levels are a pre for pro work, but useless for home hifi. jan didden
/Yes! Its out: Linear Audio Vol 5! I'm not an "accademic", just a plodder who loves a challenge - Ian Hegglun |
#3 |
This actually the same ic as the obsolete Wolfson volume control.
#4 | |
Edit: 8816. Still have the data sheet. jan didden
#5 |
Found there's already a thread on this. I posted up the link because the datasheet had a very recent date on it - seems its not such a new part as that date suggests.
WM8816 based pre-amp
#6 | |
here the currently URL for the datasheet of DA6116 from Micro Analog Systems: http://www.mas-oy.com/uploads/Data%20sheets/DA6116.pdf and an additional thread to the same topic: WTB: MAS DA6116 or MAS9116 or Wolfson WM8816 |
#7 |
If anyone's interested in exploring alternative options for volume controls, these ADI chips are worth a look:
AD603 | Low Noise, 90 MHz Variable Gain Amplifier | Differential Amplifiers | Specialty Amplifiers | Analog Devices AD605 | Dual, Low Noise, Single-Supply Variable Gain Amplifier | Differential Amplifiers | Specialty Amplifiers | Analog Devices I've prototyped AD603 in the I/V stage of a DAC, sounds transparent to me. Still playing with AD605.
| Digitally controlled relay volume regulator | veteran | Digital Line Level | 71 | 17th January 2011 01:31 PM |
| A digitally controlled volume control solution | ybserge | Chip Amps | 2 | 4th January 2007 09:31 PM |
| Digitally Controlled Volume, Tone IC ?? | metal | Chip Amps | 55 | 8th August 2005 11:35 AM |
