Go Back   Home > Forums > Source & Line > Analog Line Level
Old 11th July 2011, 07:28 AM   #71
UMarcus is offline UMarcus  Germany
This weekend i had finish my "breadboard"
Old 11th July 2011, 10:48 PM   #72
DQ828 is offline DQ828  Australia
DQ828's Avatar
Looks good & a lot of fun
Old 11th July 2011, 10:53 PM   #73
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Originally Posted by veteran View Post
I forgot that i'm changing my hosting provider so here are direct links to selector documentation. I will fix this in a couple of days.
Documentation:
http://www.dma.win.pl/unisonus/pdf/s...umentation.pdf
http://www.dma.win.pl/unisonus/pdf/selektor/... materials.pdf
Diagrams and drawings of the PCBs with dimensions
http://www.dma.win.pl/unisonus/pdf/s...roller_pcb.pdf
http://www.dma.win.pl/unisonus/pdf/s...roller_sch.pdf
http://www.dma.win.pl/unisonus/pdf/s...lector_pcb.pdf
http://www.dma.win.pl/unisonus/pdf/s...lector_sch.pdf
Hmm... Error code sounds kind of... Sexy.
Code:
[Error : Błąd]
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative.
Old 12th July 2011, 03:58 AM   #74
veteran is offline veteran  Poland
veteran's Avatar
Code:
[Error : Błąd]
Residues after moving to a new server, but links from page 2 of this thread work without a problem
Documentation:
http://www.unisonus.pl/pdf/selektor/...umentation.pdf
http://www.unisonus.pl/pdf/selektor/... materials.pdf
http://www.unisonus.pl/pdf/selektor/...roller_pcb.pdf
http://www.unisonus.pl/pdf/selektor/...roller_sch.pdf
http://www.unisonus.pl/pdf/selektor/EN/selector_pcb.pdf
http://www.unisonus.pl/pdf/selektor/EN/selector_sch.pdf
Simple audio solutions
blog.unisonus.com
Old 11th August 2011, 02:49 AM   #75
Hello,
I am interested in purchasing 2 sets of boards with with all parts if possible for the preamplifier with selector and volume control.
Thanks,
Dominic Maratt
Old 15th August 2011, 09:34 AM   #76
veteran's Avatar
Hi djmaratt,
boards and sets are still available.
blog.unisonus.com
Old 14th December 2011, 09:37 PM   #77
I built this board this summer but haven't used the remote feature until now. When I tried I found that I mounted the motor driver, BA6418N, backwards (clumsy...). When I tried to remove it, two legs from the IC broke (inside the IC) so I cannot use it any more.
Does anyone know where to buy a replacement part in the EU. It doesn't seem to be in stock at any of the distributors I have used (elfa.se, farnell, mouser,...). Veteran: you do not happen to have a spare one that I can buy?
Old 15th December 2011, 06:45 AM   #78
veteran's Avatar
Not a problem. PM me so I can send you one from my stocs
blog.unisonus.com
Old 17th December 2011, 01:44 PM   #79
veteran's Avatar
This is my new preamplifier which I'm testing (I'll use it in this project). Seems promising
blog.unisonus.com
Old 17th December 2011, 02:28 PM   #80
Arkudos is offline Arkudos  United States
Veteran,
What are the differences between this new preamp board and your old board? Are the new boards available yet? I would love to make a set and plug them in to compare the two.
Ark
FS (2) Alps pots motorized nvrgdenuf Swap Meet 0 1st August 2010 01:37 AM
alps 6 ch motorized pot help wanted glorocks Parts 6 23rd June 2010 04:19 AM
ALPS 100KAx6 (008M) motorized - wanted! macekw Swap Meet 3 22nd June 2010 06:34 AM
Motorized selector switch portreathbeach Parts 3 16th February 2010 03:54 AM
Alps 100K Motorized pot pinouts wboyd Parts 1 24th November 2004 06:47 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
