Passive (active) preamplifier with selector (motorized ALPS, IR) - Page 7 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 28th June 2011, 08:00 PM   #61
UMarcus is offline UMarcus  Germany
Picture of my "Breadbopard"
Old 29th June 2011, 10:19 AM   #62
DQ828 is offline DQ828  Australia
DQ828's Avatar
Looks very interesting, do you have any left? How much to send to Australia?
Old 30th June 2011, 07:43 PM   #63
veteran is offline veteran  Poland
veteran's Avatar
DQ828, it depends from package weight but usually it's about 10-15$ (registered air mail).
Simple audio solutions
blog.unisonus.com
Old 30th June 2011, 07:49 PM   #64
veteran's Avatar
I forgot that i'm changing my hosting provider so here are direct links to selector documentation. I will fix this in a couple of days.
Documentation:
http://www.dma.win.pl/unisonus/pdf/s...umentation.pdf
http://www.dma.win.pl/unisonus/pdf/selektor/... materials.pdf
Diagrams and drawings of the PCBs with dimensions
http://www.dma.win.pl/unisonus/pdf/s...roller_pcb.pdf
http://www.dma.win.pl/unisonus/pdf/s...roller_sch.pdf
http://www.dma.win.pl/unisonus/pdf/s...lector_pcb.pdf
http://www.dma.win.pl/unisonus/pdf/s...lector_sch.pdf
blog.unisonus.com
Old 1st July 2011, 12:31 AM   #65
DQ828's Avatar
Hi
The links don't work.
I was wondering how much it cost all up? Including the goods.
Documentation:
Old 2nd July 2011, 03:25 PM   #66
veteran's Avatar
I finally fixed the problem so links (excluding post #64) should work right now.
DQ828 take a look at the end of page 2 of this thread:
blog.unisonus.com
Old 2nd July 2011, 03:38 PM   #67
veteran's Avatar
I also found some nice little remote which should fit into this project.
blog.unisonus.com
Old 2nd July 2011, 04:20 PM   #68
eclectic2k's Avatar
speaking of remote...
I have a "wishlist" item. Is there any way to implement a discrete on & off IR code in place of the power toggle? (I like using macro's on my programmable remote to turn on multiple things at the same time)
I'd be fine buying a replacement microcontroller from you...
thanks
Old 2nd July 2011, 05:09 PM   #69
veteran's Avatar
If I understood good you need separate buttons (on remote) for ON and OFF (on to turn if selector on, and the other to turn it off)?
blog.unisonus.com
Old 2nd July 2011, 06:04 PM   #70
eclectic2k's Avatar
yes.
so that the on/off relay (REL1 on CON1) can be turned on by one IR code, and turned off by another separate IR code.
this would be great if you could fit it in the program. I use a universal remote, so I have plenty of buttons and codes I can pick from. I just need the logic in the receiver. (otherwise I was considering somehow using REL2 signal and building some extra logic around them. - but that's a bit of a hack )
thanks for taking a look at it.
FS (2) Alps pots motorized nvrgdenuf Swap Meet 0 1st August 2010 01:37 AM
alps 6 ch motorized pot help wanted glorocks Parts 6 23rd June 2010 04:19 AM
ALPS 100KAx6 (008M) motorized - wanted! macekw Swap Meet 3 22nd June 2010 06:34 AM
Motorized selector switch portreathbeach Parts 3 16th February 2010 03:54 AM
Alps 100K Motorized pot pinouts wboyd Parts 1 24th November 2004 06:47 AM
Copyright 1999-2017 diyAudio
