Balanced output confusion
Old 4th February 2011, 12:49 AM   #1
johnmarkp is offline johnmarkp  United States
Default Balanced output confusion
I have a slight 60hz buzz in my new preamp. It is just loud enough to drive me nuts, but not bad really. It is a differential circuit that I am running into a single ended amp. I have been toying with the idea of going to a true balanced amp. How do I test my preamp to make sure the change to a balanced amp will remove what I hope is a common node buzz. The more I think about it the more I get confused. I have a computer based two channel oscilloscope and another balanced preamp. Any suggestions would be appreciated.
John
Old 4th February 2011, 01:14 AM   #2
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Could be an earth loop problem.
Try adding an earth connection to the ground line.
Or try removing the earth from the ground line.
Dont disconnect the earth from the chassis.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 4th February 2011, 10:28 PM   #3
Bill Fuss is offline Bill Fuss  United States
RIP
It really depends on the input and output circuitry and how you have them connected. Are you using one phase and ground from the preamp or tying one of the output phases to ground at the amp. You could always use a trafo at the amp input.
Old 4th February 2011, 10:49 PM   #4
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
The easiest way is to unplug everything from the input to the amp, if the noise goes away then it's probably a ground loop and going to full balanced should cure it.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 6th February 2011, 03:46 PM   #5
DF96 is offline DF96  England
Can you see the buzz on the output with your 'scope? Is it common-mode or differential-mode? Does the preamp have a true balanced output, or just a rough approximation such as a phase-antiphase output pair? Can you ground the other output phase instead?
Old 7th February 2011, 02:10 PM   #6
R.I.P.
How do we test for this?
regards Andrew T.
Old 8th February 2011, 09:33 AM   #7
Put the scope on both outputs simultaneously. See if buzz signal is in phase or inverted on one of them.
Old 10th February 2011, 10:43 PM   #8
Well I put both channels on the scope and they were in phase. I hooked it up to my other pre amp that does not have the same noise issue and it was gone when I hooked it up balanced but there with SE. I am 90% sure that it is an issue involving poor placement of the transformers. I am going to do some shielding experiments and see if it helps. The pre is a true balanced design, assuming that an ARC ref3 is a balanced design.
Thanks all
Old 11th February 2011, 11:20 AM   #9
If it is in-phase (i.e. common mode) then probably caused by grounding. If there is an output transformer then grounding is about the only possible cause. If the balanced out comes from op-amps etc. then it could be PSRR within the circuit, or internal grounding issues.
Common-mode noise will always disappear when connected to a true balanced input.
Balanced output confusionHide this!Advertise here!
How to mix few balanced output? Steinberg Analog Line Level 3 20th November 2010 03:30 PM
How can I check if its balanced output Pbassred Everything Else 9 11th December 2006 10:54 PM
RIAA with balanced output? roger-k Analogue Source 19 17th March 2006 04:42 PM
output diode bridge confusion Danko Power Supplies 4 17th August 2005 10:45 AM
balanced output wuffwaff Solid State 14 16th January 2002 06:54 AM
