Go Back   Home > Forums > Source & Line > Analog Line Level
Old 17th May 2011, 11:28 AM   #181
Elbert is offline Elbert  Norway
I see, so still some way to go on the complete DSP7DAC package then.. Hope it doesn't drag out and get fraught with issues as my amp/x-over project did! But you seem to know what you're doing anyway..
Regarding generic calibration files, I really agree with you, wish there was a way I could check my mic without sending it off to proper calibration, something which would probably be many times more expensive than buying a new one of the more affordable type..like your ECM8000.
Yes, the Visit at SEAS was really great, we were given a tour by.. was it Tore Tambs Lyche..?, anyway, one of the really senior guys with a long history in the industry, lootss of info, both historical and technical, it was a real privilege!
Yes, that black Excell midrange is the last "odd job" I can remember seeing, but only at Madiound, nothing like that from the Norwegian distributor these days...
I agree that the standard SEAS line-up doesn't leave much to be wanted, but picking up some "exotic" special at a bargain price is something we all love, or what?
By the way, wasn't that black W15CH001 really a midrange??
Ah, the monacor waveguide.. still, will be very interresting to see how it turns out. But do you need to remove the faceplate from the tweeter?
My self, I'd be happy if I can get all the filling and veneer work done so I can have both my subwoofers finished and up & running soon!
Old 17th May 2011, 10:44 PM   #182
5th element's Avatar
Indeed, it's only taking a while because I am waiting for a response over on the TI engineering forums. I've got some ideas myself, I just want some confirmation/guidance before I go ahead and make another PCB.
I don't remember who it was, but there used to be a guy who'd calibrate your ECM8000 (presumably he could do other mics too) if you sent it to him. You paid a small fee of course, but it wasn't outrageously expensive, more like the price of the mic itself, which considering the ECMs price, isn't too bad at all.
Now you're really making me jealous
Sadly not, if it was I'd have snapped up a pair, even with the large shipping costs from the US. The specs were identical to this and as it stands, in my opinion, the W15CY001 is a superior driver. According to Zaphs measurement it's got ever so slightly less distortion in the area I am interested in and slightly higher sensitivity. In an ideal world, I'd like a hexadym magnet midrange of around 5" in diameter, with a light magnesium cone that has around ~90dB sensitivity re 8 ohm watt. Of course the break up would have to be as high as the W15CY001s, or ideally a little bit higher to keep the distortion peaks associated with that break up high enough up in frequency as to be as avoidable as possible.
Zaph Audios own ZA14 is pretty much what I'd have in mind, higher sensitivity, ever so slightly smaller radiating area, higher breakup and lower harmonic distortion. With a bit of refining in the direction of a dedicated midrange, I'm pretty sure the sensitivity could be increased by a couple more dBs. If I lived in the US I'd by a pair and give them a go, trouble is shipping from the US makes that a little prohibitive.
Other midrange drivers I'm interested in would be the midget little scan driver, the C173-6-090 from accuton, the 6ND430 from 18 sound and possibly the 15M/4624G00 from scan speak.
The accuton and the 18 sound driver both have brilliant specs and are sensitive too. The accuton is ridiculously priced though and over the 18 sound driver I cannot for any reason justify spending that much money on a driver, especially one as fragile as the accuton. The 18 sound is a pain in its own right though, a Square frame? Who the heck thought that was a good idea, these are a royal pain in the behind to flush mount.
The tiny 10f scan speak mid has some amazing numbers and if used right could sound fantastic, it's not too expensive either so that makes it even more attractive. The 15m on the other hand could be the better choice as its a bit more sensitive and should have far more low end capabilities. My only problem with the 15m is the impedance bobble at ~1500hz or so, lots of scan speak's relevelator drivers show this too and it doesn't affect the harmonic distortion at all, but I do not know if this carries on into the discovery drivers. If the 15M has distortion numbers like the 10F, it'd be one helluva midrange driver at a very attractive price point. Hopefully someone will get one to measure!
From this website it would appear so. The diameter of the ring dome appears to fit neatly inside the inner diameter of the wave-guide. I will have to see what's required when the WGs get here.
I detest 'finishing' loudspeakers >.< Yes I like the end product, but it's always so much work to make them look pretty and it's not the fun part of the work involved in designing a loudspeaker either!
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 18th May 2011, 09:36 AM   #183
Considering the effort and complexity, I can sure understand that you'd like to get those boards right first time arround! Just thinking about how much work it was just to make those boards for my amplifier project, and that ws simple one-sided stuff!
Apparently, Parts express has an affordable mic that comes with a calibration file, so I might pick one up next time i'm in the USA.. but then again.. perhaps I can live with a degree of uncertaintly in the top octave, after all my mic has proved to be usefull no end to sort out x-over frequencies and phase issues in the midrange, which is still way more than I could ever anticipate as a happy amateur only some years ago!
I agree that the new midranges from Scan-speak look very sexy,especially for the price! I'd definitively be looking in that direction my self if I were contemplating a 3-way system.
A hot tip regarding midrange by the way: SEAS G17REX/P or RE/P, officially obsolete from SEAS, but the norwegian SEAS dealer still stock the RE/P. It has a VERY nice midrange.
I have a couple of these in a pair of small boxes I threw together once which my brother is borowing.. I'm tempted to take them back and do something serious with them..
Get a cheap air ticket to somewhere in the US, have stuff shipped to your hotell address, buy losts of clothes (especially jeans), etc.. and before you know it, you have saved the fare!
Regardingfinishing, I'm not to fond of filling and priming as it seems to take forever between endles re-applications and is a right mess with sanding and dust everywhere.. But when the surfaces are finaly flat and the corners are sharp, I really enjoy laying down that veneer, not to mention seing the colour and glow of the wood come through as laquer or oil is applied!
Old 18th May 2011, 02:37 PM   #184
Making the PCBs is no trouble, I've had the method solid for a number of years now. Throughout the years I've done around 7 different prototypes the PCM1794/92 DAC chips and never arrived at a performance level that I am happy with.
I don't think errors in the top octave area much to be too concerned about, although that's only if the mic has deviations that are around 1-2dB away from being accurate. I think the microphone that you're talking about is one that I've seen discussed over on the HT guide forums a number of times. From memory the calibration data is simply a piece of paper with a SPL graph on it. You could always take a picture of this with a digital camera then use SPL trace to create your own calib file, although I cannot remember if the calibration SPL graph was really any good in the first place!
I might end up buying one and giving it a measure, here's hoping someone else does first.
Mmm I've heard about that one and seen peoples favourable comments regarding it's mid-range.
This is the bit I am fond of too. I don't necessarily dislike finishing really, the bit I do not like is all the sanding required to get a mirror like shine. If an ultra smooth and reflective surface is not required then it isn't too bad.
As it stands the WG300 arrived earlier on today, so I'm going to go play some! The WG by the way is about 16.5cms in diameter so just a bit larger then a W15 and almost perfect in size to mate with a 6.5" driver - makes that damned accuton look even more attractive.
With regards to removing the XT25s faceplate, it doesn't look like this is necessary, although it would probably mate up particularly well if done this way too.
Old 18th May 2011, 08:22 PM   #185
A few hours later and we have some success. The pictures are of bloody awful quality as the three digital cameras we've got are currently elsewhere >.< I had to make do with the camera built into a mobile phone, pfft.
The WG300 is actually very easy to work with and due to the mounting holes that are already embedded and tapped within the wave-guide itself, it makes mounting stuff to it very easy.
The throat of the wave-guide matches the diameter of the XT25s diaphragm extremely well and appears that it would also mate fairly well to a number of tweeters without too much issue, the only problem is securing the tweeter to the wave-guide.
To solve this I made a mounting plate out of 3mm thick aluminium, this is fixed to the wave-guide by the 4 holes already described. Then to secure the tweeter I tapped 6 3mm holes into the aluminium so that the tweeter could be screwed into place. 4 holes are for mounting the DXT and the extra 2 are for mounting the XT25.
Three of the holes match up to the screw holes in the XT25s faceplate.
Now all that's left is to screw everything together and make sure everything is lined up.
Complete with test baffle.
Using this method it would seem extremely easy to mate any tweeter to the WG300 without too much issue, just tap more mounting holes and you're set.
Due to the wave-guide already present on the DXT, the throat of the WG300 won't press directly up to the fine wire mesh in front of the DXTs dome. I don't know if this will have a huge impact on the measured performance, I shall have to do some measurements, they come next!
The tweeters I have my eye on that could make a wonderful combination would be these, they are already well known and well liked. Considering their performance, the two should mate up really well. The wave-guide giving a boost to the low frequency region and the tweeter already boasting extremely low distortion low down too. The only limitation to how low this could go, being the excursion limits of the tweeter itself.
Old 18th May 2011, 09:54 PM   #186
Now for the fun stuff the measurements.
First up is the XT25
The first thing to notice is the very smooth response. All these measurements were taken in unfavourable conditions, so some small room reflections show up making the response a little ragged, but overall they are pretty decent.
Like this the XT25 also has very good distortion performance too, excellent 3rd, 4th, 5th and 6+. Only the rising second harmonic @ 3khz lets it down. I originally tried running the test @ 2.8 volts rms, the tweeter wasn't happy like this at all, something buzzed around 600-900 hz, not that the tweeter would be used down this low anyway, but I had to turn it down a little for it to be happy. Due to the extra output provided by the wave-guide you could probably get away with 1500hz 4th order slopes. The buzzing sound at 900hz was caused by the phase plug arrangement and might not be present in the scan speak versions with their better quality control.
Now for the DXT.
Shock!
I thought this might happen The spacing described above is obviously not anywhere close to being adequate, this creating a huge suck out centred on 4khz. Not much to say other then that, distortion performance looks nice though.
Out with the plasticine! DXT version 2.
Ahhh much better. My 5 minute low tech filling in of the gap with plasticine has helped things considerably, the 4khz suck-out having vanished completely. Now however there's a dip in the top octave and as you go off axis another narrow suck-out appears. I am sure I could improve things considerably if I spent more time creating a better transition between the mesh grid and the wave-guide, currently it looks a bit like a 2 year old made it Distortion performance is excellent, it's clear that this is a better tweeter compared to the XT25. You might just be able to get away with a 1khz xover with 4th order slopes, this would have to be measured though to find out and I do intend on trying this out.
One thing that's interesting is the DXT distortion performance, here is a graph of the DXT in its own small wave-guide.
As can be seen there's a broad hump in the third harmonic around 1-2khz. This same hump can be seen in Zaphs measurements of the DXT too. However when using the WG300 instead of the DXTs own wave-guide this hump completely vanishes. I had assumed this was an issue with the motor/dome/chamber etc, but it appears like it's created by the wave-guide instead. Either that or the WG300 suppresses the peak.
The wave-guide appears to work rather well though, probably giving constant directivity down to around 2.5khz. The off axis curves can't really be directly compared as I didn't have a protractor around to give accurate angles, however the overall trend is easy to see. I probably went out to around 60 degrees.
This has me wanting to buy a pair of the scan tweeters I linked to before and trying those out. Tomorrow I'll probably pull some scan D2905/95s out of a finished design and test out those too.
Old 19th May 2011, 12:56 PM   #187
Wow, great stuff 5th!
First of all, What about starting a new thread on this and moving these latest posts?
I think your experiments and measurements deserves a thread of their own rather than having it alll burried deep in some old thread which has now deviated considerably from the original theme.
This would of course allso make it easier for other people to find and make use of what's being posted!
The XT25 certainly looks promising, hope it is easy to smooth out to flat with a "standard" filter slope too!
But why would you add the waveguide to the DXT tweeter?? That would sort of be a waste of the DXT waveguide/ lens allready in place.
Funny, I actually have a pair of the D2608/913000 on the shelf, bouthg them on impulse but then later decided to go for the DXT tweeter for my project..And since I allready have them, it would make good sense to try them for a future wave-guide/ CD project.
If it hadn't been for the relatively expensive shipping, I would have been happy to lend them to you for some testing!
The short time i tried them, they did sound very nice, perhaps a touch bright in the top, you might say they made their precence somewhat more known than the very neutral sounding DXT tweeters, allbeit not in any objectionable way.
Very good mounting description by the way, and a nice adapter! Do you have access to a lathe or something?
Will be very interresting to see what the result will be with the D2905/95s when you get arround to it!
Im particularilly curious about what difference there will be between a phase-plug/ ring radiator design and a "conventional" high quality dome, so it will be great to have a comparison with the same equipment, not to mention any subjective listening impressions you might provide!
Oh, what's that midwoofer unit I could see in some of the pictures by the way?
Old 19th May 2011, 06:17 PM   #188
I'm not quite ready to start a new post with things yet. I need to get the DSP working with all 8 channels before I can make any subjective conclusions and investigate how best to use/integrate the wave-guide. I also want to post a specific type of measurement that require a very precise measurement technique with respect to the off axis.
Here is the d2905/95
It works rather well. Here it is hammered flat with the DSP + a 4th order acoustic LWR filter.
This still looks very nice. The tweeter wasn't happy using a 1khz xover, moving it up to 1.5k was possibly useable depending on how loud you want things to be. Mind you I wear ear defenders when doing distortion tests as it hurts otherwise, so I guess it can prolly go loud enough at 1.5k.
The only issue I can see is the bunching up of the off axis response @ 16/17khz. I don't think this is enough to make anything sound bad, it might add a touch of brightness.
The d2905/95 required three notches in combination with a 4th order electrical filter to get it flat, the XT on the other hand does this with only 2 notches, one these also only works at 10k+ and by a small amount, so it might not actually be needed.
The idea was to use the DXT's motor + dome in conjunction with the WG300, effectively bypassing its own wave-guide completely. This did not work very well, even faffing about with the plasticine wouldn't get the top octave to come together, and although it did improve things a bit, it made the 5k region a bit lumpy.
I'm going to hold off on buying any more tweeters until I've properly evaluated the wave-guide with the ones I've got. Between the D2905 and the XT, I should be able to draw some decent conclusions.
Shipping can be a damned pain sometimes!
I think this has been said about them elsewhere too, they've got a very lively top end. The good thing about the wave-guide is that it should give every similar 1" dome tweeter, providing they mount to it successfully, roughly the same off axis response, making them perhaps easier to compare.
Nah, a lathe would be nice, but we don't have the space for one really. I did all of that with the circle cutter on the router.
See above The one thing that is nice though, is that the D2905 looks very use-able and it's dome/faceplate arrangement isn't anything special really. I think you'd be able to mate pretty much any 1" dome to the WG300 providing it doesn't have some complicated faceplate.
I am interested in this too, I must get the other DAC channels finished
It's an RS225, it's an 8", which shows that the WG300 is pretty large 170mm diameter.
Having stereo = 2 channels is kind of limiting, but I didn't let it hold me back. I tried a quick mono 2 way using the XT and the RS225. I crossed them at 1500hz 4th order. The frequency response was flat as a pancake and phase integration was excellent. The distortion was also very low at the levels I was listening at. It did not sound good though, something was melting my ears off. I tried playing the piano (synthogy Ivory2 grand ) through it and noticed that certain notes made my ears jump and want to hide away, this doesn't occur on the headphones and hadn't on the previous analogue active xover. I got the spectrum analyser of ARTA out and found that the objectionable content was centred around 3-5khz. I am not entirely sure what this could be. I am currently rebuilding the cabinets and the translam for the W15s aren't done yet, I really need them done I think to make any realistic conclusions though.
The RS225 has a peak in the distortion plot at 1.5khz, and while not really that high, it could be contributing to it. There's a spike in the third harmonic there and any 1.5-1.8khz stuff will excite this giving output in the 4-5khz range. The relative level of the distortion is still low mind you so I am not convinced that's the issue. Using the W15 will be an easy way to see if this is the cause. Also the XT would prefer being used a bit higher, at least 1.8khz or so.
The measurements I've done don't really describe why I am hearing what I am, but something has to account for it.
Old 5th November 2011, 07:44 PM   #189
Summer has passed, and with a wet and cold autumn, it's back to stereo projects again!
Today, I perfected my stereo set-up.
Not long ago, I finished my subwoofer project, and after some level fine-tuning, I got a very flat response in my listening position down to about 30 Hz and and a very controlled and deep bass reproduction.
Completed build, for inspiration..
At the end of the above thread, you can see the in-room measurement. As you can see, there si a considerable droop in HF response, but bear in mind that this is the listening position, not a gated on-axis measurement.
Still, I felt that a lot of recordings missed some detail and life.
did a measurement without the HF equalisation as input to LSPCAD and ran some optimalisations. No huge changes, merely a 2 dB boost at 15k and about 0,8 dB at 5k relative to what I was allready running.
Modified the filters and put them back in; Perfect! Now there is no feeling of anything missing, and yet no signs of excessive HF or listening fatigue. things finally came together.
Enclosed, you can see measurements before and after this last tweak. Obviously not dramatic, but this was all it took to get it right!
(Bear in mind that as my mick is home-buildt running a "generic" calibration file, the measurements are not absolute in the upper frequencies.)
Apart from seriously brushing up on my electronics, this project has been a very good excercise in how to combine critical listening, measurements and the use of tools like LSPCAD to acheive results which goes well beyound what I expected in the eraly days of this project.
A final thanks to all that contributed!!
Old 6th November 2011, 10:08 PM   #190
You know it was by shear luck that I found this updated and only a day after you'd posted too! Often small changes in the high frequencies are not performance breaking but they do add the icing to the proverbial cake. I know I am quite sensitive to high frequency tuning, too much tilt upwards and it's too much, too little and all the sparkle goes away, some tweeters seem to sparkle more easily then others, whereas some sound gritty and dirty with too much high frequency energy going on and you can never strike the right balance.
Interestingly it's the wave-guides I've found that help keep a tweeter sounding effortless, clean and scintillating in the last octave. Even with the wave-guides it is still all to easy to have the tweeter level set a step too high and once that happens the balance is way too in your face.
It's nice to see that you've created a build thread too Everyone loves pictures of progress/finished systems.
The RS subs I bet were the very nice way to top everything off. Those drivers do strike a nice balance between performance and value for money. I did entertain the idea of putting two 12" RS subs into a large ported cabinet, but gave up on that idea when I realised how much of the room it would take up! I'll stick to my 12" cubes + XLS10 for the time being.
And the neighbours be damned, I bet you love finding music with monster bass and cranking it up
1st order Passive Line Level Crossover + 2nd order Highpass? alexclaber Multi-Way 11 4th January 2008 07:15 PM
deceptive perception ? 1st order-2nd order question poldus Multi-Way 4 10th April 2007 11:58 PM
high gain 2nd order high pass active filter topology sreten Solid State 21 23rd March 2006 01:26 AM
3rd order HIgh pass filter - explanation? APaddy Analog Line Level 12 24th January 2006 08:06 AM
Aleph P.17 1st order high pass filter Ignatz Pass Labs 2 30th October 2002 06:56 PM
Copyright ©1999-2013 diyAudio
