ok - so my parts are on order - hopefully I'll get this device functional the 2nd time around --
for testing the device out of an enclosure, does anyone have any recommendations on how to deal with the ground loop humm?
The kit's pcb has a ground connection point that is intended to connect to chassis - what could I use to temporarily ground the device?
Thanks!
Ted
Thanks!
Ted
projet update
ok - I've got the device working - it performs very nicely as is -
I had thought of increasing the size of filter caps, but the DC output is very smooth - so I think I'll leave it as it --
testing the unit, I have figured out how to ground the board and prevent ground loop hum --
So now it's time to build and enclosure - I stopped by a friend's shop and he had a nice enclosure in his salvage pile - it's just the right size, but it's made out of stainless -- so making holes is going to be a bit of a challenge...
question on determining hot side, chassis contact
stuck in enclosure building phase...
hoping to find 100mA 3AG fuses locally...
plan for power cable:
3 prong 110V power cable to interconnect = 2 leads from transformer.... ground lead to shared chassis ground lug....
fuse and switch wired on hot side of transformer (not exactly clear on how to determine this)
3 secondaries: AC+ 0 AC- connections on pcb -- ground pcb to shared chassis ground --
the one connection I'm a little nervous about is the transformer primaries to the interconnect - its fairly close to the chassis -- can the wires make contact with the chassis if they are well insulated/heat shrink wrapped?
problems with ground hmm
so I found a stainless steel enclosure -
mounted the transformer directly to the bottom of the chassis
used a 3 prong interconnect - ran ground prong to chassis ground
used a grounded toggle power switch - ran ground prong to chassis ground
pcb has a mount for ground connection -- ran that to chassis ground
I'm getting a ground loop hum -
I'm not sure if my transformer it too close to the pcb or if all of the ground connections are interacting with one another --
Will try removing the ground connections from the interconnect and the power switch....
When I remove the pcb from the enclosure and set it further away from the power transformer I don't get hummmmmm......
hmmmm......
hmmmm......
project update
ok - good news -
my ground loop issue was due to a bad ground connection -
I redid the ground connection shared by the pcb and the 3 prong IC and everyone is getting along now -
I've been using the device and it is operating normally --
I'm contemplating increasing the size of the caps in the filter - but I don't think this would improve sound quality...
Hoping to button up the enclosure tonight - just some minor cosmetic issues to finalize --
ok - good news -
pictures of finished project!
Velleman pre amp kit K8084 - Google Photos
one possible issue: the hot mains wires are enclosed with shrink tubing - but are they too close to the side of the enclosure?
Hello some pictures of mine
works a treat also added volume remote control .. very pleased with the sound, no hum etc very silent
Thanks for the pictures! definitely worth 1K words! Now I have some great ideas for my next project - I wasn't sure how to move the pots and rca inputs off the board -- now it all makes sense --
I see the correct way to rise the pcb off the chassis as well with the metal risers -
Thanks!
T
Thanks!
T
Thanks!
T
Hello
This was my 1st build with the tone control preamp .. I used a extra external power supply (+/- 15v) and fed the preamp PSU as this regulates down to 9v on the PCB.
Next time I would use screened cable, although in the current layout there is no issues .. also make sure you earth the pots
regards
Can you post a close up picture of your op amps jamesfeline?
Hello
The op amps I used :
Bur Brown OPA2134PA
- Analog Line Level
- Velleman K8084 pre-amp kit question
