| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
Hi
I plan to use an AD/PMI BUF03AJ/883 Buffer in the Input section of a High-Pass Alignment Filter to drive the filter with very Low impedance so that its Q is strictly maintained. The BUF03 has Trim offset adj using Pins 1 & 5. A +ve supply with a 5k trimmer is to be used as per the suggested circuit. Could members kindly outline How to null the offset of the BUF03 and what all needs to be done to achieve this? Thanks in advance! ~Arup |
#2 |
Unless I am missing something:
1) Build circuit as per schematic 2) Short input and connect meter across output 3) Power up circuit 4) Adjust trimpot for 0V DC-offset 5) Leave circuit to warm up and mnitor offset as circuit warms up 6) Readjust offset if necessary /U. |
#3 |
@ Nisbeth
Wonderful.... Thank you so much! |
| Dc nulling Servo amp need help | Acoustat | Solid State | 32 | 27th April 2011 08:30 AM |
| BUF03 equivalents | tubenut | Digital Source | 7 | 25th December 2007 10:07 PM |
| Offset nulling - kind request of advice | beppe61 | Solid State | 13 | 9th May 2007 11:47 AM |
| Output buffer offset voltage | borges | Analogue Source | 0 | 24th August 2004 12:03 PM |
