10band equalizer
10band equalizer
Old 17th January 2011, 08:30 AM   #1
generator***** is offline generator*****  Turkey
Default 10band equalizer
Hi friends. I draw a pcb for 10 band equalizer schematic.what do you think about this pcb?? grounding is ok??
Old 17th January 2011, 04:50 PM   #2
mickeymoose is offline mickeymoose  Canada
generator:
Looks nice! Your layout seems OK. I would mover the part designators (ie R1, R2....) from underneath the parts to the side of the part. This way they are ledgible after assembly. Why the jaggy red (top layer?) lines in the middle? Also I would route all the pot connections to one side for easier assembly. Rotate CON2 so wires exit to fewer sides
This is a cut-only EQ generally used in room eqalization. Personally, I prefer each third filter to go to a different op-amp for a different combining effect.
Well, you didn't ask for all that, but sumtimes I ramble...
E
Old 18th January 2011, 10:19 AM   #3
top layer is used for input signal of filters. thanks for advices for part routings
10band equalizerHide this!Advertise here!
equalizer dr dingwhizzer Analog Line Level 9 29th April 2018 12:09 PM
Impedance Equalizer sparkless Multi-Way 6 7th July 2009 11:38 AM
Building An Equalizer bezeek Parts 4 28th January 2007 08:40 PM
Kenwood Equalizer sandman Solid State 2 5th November 2006 09:27 PM
gainclone and equalizer JOJO847 Chip Amps 5 2nd June 2005 01:22 PM
