LED VU meter using existing bar graph - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 12th January 2011, 06:55 PM   #1
Preamp is offline Preamp  Germany
ulti.preamp.org
Preamp's Avatar
Default LED VU meter using existing bar graph
Hello everybody,
I need some help on designing an LED VU meter. The well-known LM3915 is not an option this time, because I want to use an existing bar graph (see attached picture).
This thing actually accepts any voltage between 0V and 10V while the displayed range is adjustable (ie. 0V...1V or 5V...5,5V).
The graph is made of 2x 101 LEDs which should look pretty neat and give a fine resolved display of the volume level.
Now: What do I need to get my level displayed in dB? I was thinking of a range like -80dB to +6dB...
Thanks in advance,
Lasse
Old 13th January 2011, 09:44 AM   #2
DF96 is offline DF96  England
You need to rectify your signal to get a DC voltage, then take the logarithm to get dB - use specialist chip or BJT with an op-amp. I very much doubt you will get 86dB dynamic range, and why would you want to anyway - do you want the lowest few LEDs to respond to recording noise?
Old 13th January 2011, 10:11 AM   #3
forr is offline forr  France
forr's Avatar
Hi Preamp,
This is quite curious, I own almost similar meters, they are labeled MORS which used to be a french trademark I think. In mine, the displays are made of fluorescent bars, not leds. I'll probably use them soon, they're pretty looking and only need to be plugged in 220 voltage mains for the power supply.
To get dB of RMS voltage, in his hardware distorsion meter, Cyril Bateman used an AD536, a 1 kOhm resistor having a 3500 temperature coefficient and an OP1770. It needs calibration. The scale is 60 dB.
Old 13th January 2011, 12:08 PM   #4
ulti.preamp.org
Preamp's Avatar
I'm going to use a PGF3000 whose datasheet says it cuts off at -100dB, so I thought I could start at 80dB to still have some "action" while listening to small volumes and make some use of that 100 LEDs... 60dB will still be fine, of course.
Sounds quite complex. Do you have a link to that project? Or is it only available as printed media?
Old 13th January 2011, 01:54 PM   #5
ulti.preamp.org
Preamp's Avatar
EDIT: Just found the schematic in AD536 datasheet.
Help with LM3915 LED VU meter Youran Digital Source 4 20th September 2009 09:47 AM
AN6882 bar graph LED drivers: what instead? Wavebourn Solid State 9 30th June 2008 08:34 PM
LED VU meter neil_kaye Parts 8 27th December 2006 07:43 AM
LED VU meter for ZV9 neil_kaye Pass Labs 1 21st December 2006 06:58 PM
led vu meter leander Solid State 3 22nd September 2005 03:06 PM
Copyright 1999-2017 diyAudio
