| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
I would like to build high quality preamplifier.
What I had in mind is, it should assume the following: - battery power supply - input switching with bipolar relays - volume control with BB PGA2310 - schematics have to be verified, I would not experiment too much... I have found something interesting, through the source I do believe in. Project is published in Elector 1/97 (edition in English). battery-operated pre-amplifier Desigh by T.Giesberts Is it OK if I publish the schematics here? I would use basic scheme and modify volume and selector parts... I would very much like to get your opinion on this project before I start building. Other suggestions (projects, schematics..) are also very welcome. Preamp will be paired with Leach Amp. Thank you. |
#2 |
Lots of choices out there. how about Preamplifier Dispre 2 - JFET ?
If you're looking to use the PGA2310 because you plan a remote control, why not use it to control a LDR based attenuator? That should sound better. If you don't need gain, search this forum for "poor Serbian man LDR based..." Attenuator and buffer or a Pass B-1 clone, you just add the input selection. |
#3 | |
I need gain stage. I would for this very preamp avoid LDR for two reasons: - I already have a bunch od PGA waiting to be used, and I really like technical characteristics of those cheaps... - I doubt that I would have to buy very large number of LDRs to match few perfectly, and again, I would add some difference by different light characteristics of LEDs... |
| Preamp suggestion required pls | milen007 | Tubes / Valves | 4 | 19th September 2009 03:53 AM |
| Suggestion for a bass preamp.. | Dxvideo | Chip Amps | 4 | 29th July 2008 01:47 PM |
| Suggestion for this tube preamp | fastvideo | Tubes / Valves | 7 | 14th July 2008 09:02 PM |
| Suggestion on the input transformer for tube preamp | bee696 | Tubes / Valves | 3 | 2nd August 2006 04:43 AM |
| PREAMP suggestion for my IRAUDAMP. | pat allen | Class D | 3 | 21st March 2005 12:42 AM |
