Question about shielded wire...
Old 5th January 2011, 02:38 PM   #1
6L6 is offline 6L6  United States
6L6's Avatar
Default Question about shielded wire...
I have a good amount of a 2-conductor wire in a braided shield. Not coax.
2 individually insulated stranded conductors of about 20AWG in a braided shield, with a layer of insulation on top of that.
When using this for single-ended line-level connections, what do you do with the shield?
I see a number of possibilities -
1. Ignore the shield and don't hook it up to anything.
2. Connect the shield to ground on both ends
3. Connect the shield to ground on one end.
4. Connect both of the internal conductors to positive, and have the shield as ground.
What would be the most common way of hooking up an internal connection with a wire like this - for example an RCA female to a selector switch to a volume pot, to the circuit.
I have not used this type of wire for internal connections before. I have used it for interconnects, having + and ground on their respective internal conductors and the shield connected to ground on one side.
Old 5th January 2011, 02:48 PM   #2
use the two cores as flow and return.
Connect the shield at one end only, probably the send/transmit end.
regards Andrew T.
Old 5th January 2011, 03:20 PM   #3
kevinkr's Avatar
What Andrew says..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 5th January 2011, 03:28 PM   #4
6L6's Avatar
Wonderful!
Gentlemen, thank you.
Old 5th January 2011, 05:25 PM   #5
DF96 is offline DF96  England
Either 3 or 4, with a slight preference for 3 - i.e. I agree with the others.
Question about shielded wire...Hide this!Advertise here!
shielded wire dosilegecko Tubes / Valves 8 30th March 2010 08:57 PM
Shielded wire fsjonsey Tubes / Valves 7 21st March 2008 04:33 PM
Is shielded wire necessary for chipamp inputs? ransom peek Chip Amps 16 6th June 2006 08:33 PM
Shielded Input Wire Bryan Tubes / Valves 5 17th August 2005 09:26 PM
Copyright ©1999-2017 diyAudio
