Go Back   Home > Forums > Source & Line > Analog Line Level
Old 1st January 2011, 05:51 PM   #1
Default the hat-trick volume control ;)
ok, so its a silly name. a hat trick is where you get 3 things in a row.
so here's 3 things in a row: 3 relay attenuators in a single package, controlled by a cpu (arduino-like thing called LCDuino).
I needed an analog volume control for my newly acquired DCX2496 crossover. this passive relay attenuator will do that for me. it runs software I wrote called VoluMaster and I'm now adding support for 'multi-board' configs such as this.
the single vol pot is a motorized knob that takes user input OR shows current vol level as set via a learned IR remote.
each board has 8 latching relays and is populated to cover 127db range in half db steps.
(the project will be open-source once the coding is complete. this is a sneak peek of the project and what it can do).
My Photostream:http://www.flickr.com/photos/linux-works/
Old 2nd January 2011, 04:44 PM   #2
maxw is offline maxw  United Kingdom
maxw's Avatar
Looks good. Why not use an encoder instead of a pot?
Old 2nd January 2011, 04:58 PM   #3
One reason might be that with a pot you have an absolute starting point whereas encoders are incremental so where to begin? Where you left off? Zero?
How do you store the last setting if you want to continue with the last setting at next power up?
I lean toward the encoder just because they don't get dirty/noisy. Is there an encoder with absolute position readout?
Old 2nd January 2011, 05:04 PM   #4
the way its designed, the motor pot 'zooms over' when you use the IR remote. since there are TWO ways to adjust things (ir and manual knob twist) keeping the knob in sync was an important design goal.
the motor shuttling happens in the background. as soon as you hit an IR up or down vol event, the relays go there immediately. the motor pot then starts to scoot over and then settled when its at the right point.
the goal is that the knob is 'always at the last vol setting'. even if you come in via 'out of band' IR and adjust it.
of course you can twist the knob directly and it will read the linear track and find the right vol db that corresponds and go there right away, as well.
rotary encoders suck for 'feel' and they have no concept of absolute positioning. I can grab a pot and put it at max or min very quickly. can't do that with RE's. I can also put the vol at halfway instantly. can't do with RE's.
that's why I did it that way.
Old 2nd January 2011, 05:07 PM   #5
exactly. RE's are cheap and easy enough to use but they are sloppy to use in practice (many are and all cheap ones are) and for high end feel, they just don't cut it.
pots don't get noisy when you use them as *control elements*. no audio goes thru mine. vcc is at one end. gnd at the other and the wiper goes to an a/d pin on the cpu along with a small smoothing cap. the cpu reads the a/d pin and if there was a change from last time it updates the relays. if the IR remote sent in a new value, the system knows that and knows it came from 'the computer' and not a human and so it knows the motor must be moved and the pot wiper value used as target value to know when the pot has to be stopped.
Old 2nd January 2011, 11:00 PM   #6
maxw's Avatar
Not sure how arduino-like your controller is but I use the Arduino - EEPROM to remember the last volume setting.
This is so true! I have tried a few different encoders and found all the cheap ones terrible. I've settled on a Bourns Pro Audio one, I think its an ENA1xxxx with 128PPR. It turns more freely than a pot but still feels very good. The Avagotech ones are also nice but not cheap.
Either way, very nice work and photography!
Old 3rd January 2011, 12:24 AM   #7
yes, I use the same.
I guess I meant that RE's with index-marked knobs don't really make sense. if you have only in-band ways of changing the volume (the knob via human hand twists) then the knob always points at the last correct location. but add some out-of-band methods (IR remote, maybe even web-controlled) and you now have a sync problem. this is why there's a motor - to solve that
motors are also cool. as a kid I salivated after the motorized pot based adcom preamps. they were so cool and I guess old memories of them inspired the motor-pot part of this.
motor pots are also *very* multi sourced and the quality really does not matter. I like aspects of design like that.
as much as I loved those old adcom mechanical motor pot devices, I grew to hate the clicky clicky nature of the RE's that were taking their place. recently I bought a few logitech duet squeezeboxes. I'm not sure I ever used a WORSE RE than the one that comes on that remote ;( RE's have to be very well done to compete with even the crappiest motor pot. I hate RE's.
cheers
Old 3rd January 2011, 12:25 AM   #8
Banned
Not so.
Nice project though, neat packaging.
w
Old 3rd January 2011, 12:34 AM   #9
if the pot has a smoothing cap (doing most of the noise control) and the software re-reads each interface and checks for 'bounces' then its not a real issue, at least that I've found. the combo of the cap and the software read-loop seems to quite down any 'wandering pots'
I did see the problem in early prototypes. but those 2 measures have been enough to keep things stable. been running this basic code base and hardware for more than a year now (in devel a long time in quite a number of permutations).
Old 3rd January 2011, 12:36 AM   #10
benb is offline benb  United States
I wish you had told Technics that! I don't know if there's some amount of current pulled through the wiper of those turntable speed control pots that makes them go bad, but SOMETHING causes them to flake out.
I noticed this before, there are cheap $1 switch-contact rotary encoders as used in car radio volume controls, but then the next (only) step up are the "nice" optical ones used for data entry in oscilloscopes and logic analyzers, and they start around $20.
And yes, a microcontroller can save "current position" in eeprom, and after perhaps a second or two with no change in the control (this is so it doesn't constantly update eeprom as the volume is changed, which may eventually wear out the eeprom's write endurance). The processor can be set to then go into low-power mode in which even the clock crystal is turned off, assuring it doesn't add any noise to the device. The encoder's outputs can go to interrupt-enabled inputs that wake up the controller when a volume change is made.
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 07:20 PM
Replacing broken volume control with digital volume control Gunawan W Solid State 19 15th December 2010 10:46 AM
i need preamp schematics w/o tone control or volume control hernanstafe Parts 7 30th January 2008 03:12 AM
The remote control paratactic volume control audio-gd Solid State 33 7th June 2007 11:16 PM
remote control motorised control for volume pot/knob CharlesY Parts 0 25th July 2005 11:12 AM
Copyright ©1999-2013 diyAudio
