The design of active crossovers- Douglas Self wants your opinions - Page 29 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 23rd October 2012, 06:02 PM   #281
Very nice ...of full moons and capacitor rolling
Old 23rd October 2012, 09:18 PM   #282
Originally Posted by CharlieLaub View Post
I would be interested to know if the same effect happens if you set up the speakers in a different listening environment, e.g. differently shaped room and/or with a different amount of adsorbing material. My guess is that the room is reflecting some energy back to your listening position that generates a comb filtering type effect and this generates an ambience effect, giving the illusion that the soundfield is high.
Room response can be very, very influential on the sound of a loudspeaker!
Try it and report back please!
-Charlie
Room does have an influence. Lower flat ceilings 9 - 10 feet do not provoke the effect. The effect was clearly present in a room with a 20ft flat ceiling and also in a room with steeply sloping eaves as in a bungalow. The effect is not psychological and was simultaneously witnessed by many people not all being in the optimal listening position. If it was comb filtering the high ceiling would have had less. The image was extremely stable and did not wander unless stereo was panned. In this case the the image formed an arc between the speakers.
Old 7th December 2012, 02:56 PM   #283
Telstar is offline Telstar  Italy
Originally Posted by Pano View Post
(opamps) Who would use them for an active crossover in the 21st century, except as input and output buffers?
Yer right! We want to use discretes
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 12th August 2014, 12:01 PM   #284
The book is very well written and provides essential information on the subject. Have read articles by R. Elliott and the book by Mr. Self completes the picture on active XO nicely. Thanks a lot for the comprehensive work !
Old 20th September 2015, 11:21 AM   #285
Default Phase oh the sum for LR4
Hello Douglas,
Just a question...
About this graph:
Why the phase of the sum is not equal to the phase of the high pass in the high frequencies ?
To discuss.
Best regards.
Francis Brooke
Old 28th September 2015, 08:11 PM   #286
I own all your books, since I'm a pro audio designer, they are usefull to me. I've already used come of your solution in design of mine.
Mik
Old 16th April 2016, 03:34 AM   #287
luvdunhill's Avatar
I am working on a piece of code to answer the question if we allow the resistors to differ "somewhat" in a S-K filter, can we arrive on a more accurate set of resistors to build an adjustable crossover with. Also, what sort of tradeoffs are there between various resistor ranges (e96 versus e24).
My design is fixed gain, using resistors that are "approximately" a ratio of 1 and capacitors that are a ratio of 2, each with 3 choices (100nF, 10nF, 1nF, 47nF, 4.7nF, .47nF). This results in a target Q = 0.707. I'm also assuming I have a list of target frequencies (I have ten values, then I multiply by 10 to cover 25Hz to 20kHz).
Here's an example of what my code has found.
t: 0.1%, f error range: 0.015% 1.296%, Q error range: 2.578% 3.542%, number of unique resistor values used (e96): 10
t: 6.1%, f error range: 0.015% 0.443%, Q error range: 2.571% 3.535%, number of unique resistor values used (e96): 18
So, t is the percentage that two resistors are allowed to vary from each other (with the constraint that the resulting resistors are available in the series (e96) specified), then a range of frequency errors (from target) and a range of Q errors (from target) and the total number of different resistor values needed to produce the combinations.
So, my question is - is there any thing else I should be interested in considering, during these "experiments"? How much variance in Q is acceptable, at the expense of a more accurate frequency value? Are there other unintended consequences of having the resistor values "differ somewhat"? (Obviously as the two values diverge, it impacts Q, so there's a very clear limit to what combinations should be considered)
For Sale: Yet-Another-FirstWatt-PSU | "CSX1/2" "Buffered F6" FE
Old 16th April 2016, 11:05 AM   #288
the errors in capacitor value are not mentioned.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 16th April 2016, 02:03 PM   #289
luvdunhill's Avatar
That could be easily modeled. As it turns out, the easiest way to deal with this might be adding a fourth capacitor at yet one more power of 10 down. This could then be placed in parallel with the other values as needed. Once actual values were chosen, then they could be measured and then a chart could be made on when exactly to engage more than one capacitor, including this fourth "adjustment" capacitor.
I could also run the simulation with a random element. The capacitors I plan on using is a type not mentioned in the book (but I would be curious if perhaps Doug would measure some!) - Rifa/EVOX MKI which are metalized polypropylene sulfide capacitors which are +/- 10%, which could be matched. For some values I would use EXFS polystyrene made by LCR components are +/- 1%.
Old 19th May 2016, 03:50 AM   #290
luvdunhill's Avatar
Similarly, for the adjustable HPF. To maintain unity gain and a target Q of .707, we need resistors in a ratio of 2. But what if we let them vary slightly? Obviously the more the resistors vary, the further from our target Q we will be. However, we can get closer accuracy to a given frequency target, if there is some wiggle room.
In this output, t is the amount the two values can differ from the ideal ratio of 2:1 as a percentage of the second resistor. So, 0.001 means the values vary from 2:.99 to 2:1.01, subject to the constraint of a valid resistor in the series. Things converge nicely around about 5% allowable variance.
t: 0.001, f error range: 0.014% 60.014%, Q error range: 0.000% 0.113%, unique resistors (e24): 9
t: 0.001, f error range: 0.017% 34.032%, Q error range: 0.000% 0.113%, unique resistors (e96): 18
t: 0.006, f error range: 0.014% 60.014%, Q error range: 0.000% 0.113%, unique resistors (e24): 9
t: 0.006, f error range: 0.017% 1.010%, Q error range: 0.000% 0.266%, unique resistors (e96): 15
t: 0.011, f error range: 0.014% 60.014%, Q error range: 0.000% 0.551%, unique resistors (e24): 8
t: 0.011, f error range: 0.017% 1.010%, Q error range: 0.000% 0.266%, unique resistors (e96): 15
t: 0.016, f error range: 0.014% 60.014%, Q error range: 0.000% 0.551%, unique resistors (e24): 8
t: 0.016, f error range: 0.017% 1.010%, Q error range: 0.000% 0.266%, unique resistors (e96): 15
t: 0.021, f error range: 0.014% 32.472%, Q error range: 0.000% 1.159%, unique resistors (e24): 13
t: 0.021, f error range: 0.017% 0.906%, Q error range: 0.000% 1.055%, unique resistors (e96): 14
t: 0.026, f error range: 0.014% 32.472%, Q error range: 0.000% 1.255%, unique resistors (e24): 14
t: 0.026, f error range: 0.017% 0.517%, Q error range: 0.000% 1.196%, unique resistors (e96): 14
t: 0.031, f error range: 0.014% 15.590%, Q error range: 0.000% 1.482%, unique resistors (e24): 16
t: 0.031, f error range: 0.017% 0.517%, Q error range: 0.000% 1.338%, unique resistors (e96): 15
t: 0.036, f error range: 0.014% 7.742%, Q error range: 0.000% 1.626%, unique resistors (e24): 15
t: 0.036, f error range: 0.017% 0.517%, Q error range: 0.000% 1.338%, unique resistors (e96): 15
t: 0.041, f error range: 0.003% 6.217%, Q error range: 0.000% 1.869%, unique resistors (e24): 16
t: 0.041, f error range: 0.017% 0.517%, Q error range: 0.000% 1.976%, unique resistors (e96): 17
t: 0.046, f error range: 0.003% 5.828%, Q error range: 0.000% 2.342%, unique resistors (e24): 14
t: 0.046, f error range: 0.003% 0.517%, Q error range: 0.000% 2.283%, unique resistors (e96): 18
Douglas Self's Active Crossovers book forr Analog Line Level 8 31st December 2010 06:20 PM
active crossovers zimjj Multi-Way 9 7th November 2010 01:58 AM
Active Crossovers zenmasterbrian Subwoofers 77 21st September 2006 06:14 PM
Copyright 1999-2017 diyAudio
