| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
Hi, I'm designing an active crossover to bi-amp a pair of fairly generic bookshelf speakers (kef crestas) mainly so when I build my own I know a bit more what I am doing. I've got a DCX2496 to experiment with but the final crossover will be analogue.
I have measured the frequency response of both the tweeters and the woofers with and without the filter (I had a -8dB/oct HPF on the tweeter @500Hz to stop the low frequencies destroying it). In the second image I have simulated an ideal -16dB/oct HPF @ 4.5k for the tweeter and -16dB/oct LPF @2.2k for the woofer in order to get the same x-over point. When I implement this with the DCX2496 it has far too much mid (you can see this after 1k). How should I design a x-over to get rid of this? Also the tweeter looks like it is resonating without the pad.. Thanks, Nick BTW legand Blue - woofer with passive x-over Purple - tweeter with passive x-over Red - woofer (with DCX2496) Green - tweeter (with DCX2496) |
| Active bi-amp - Which electronic crossover? | rhapsodee | Multi-Way | 42 | 17th December 2012 10:56 PM |
| 3 way design help with bi amp bass section | djwhog | Multi-Way | 3 | 3rd November 2010 01:50 AM |
| Gaincline Bi-Amp / Active Crossover - work in progress | gainphile | Chip Amps | 10 | 5th January 2008 11:35 PM |
| Bi-amp 3 way design selection and calcs | fat_terry | Multi-Way | 0 | 8th November 2006 06:05 AM |
| Amp NFB network - can be used as crossover for bi-amp ? | gene57 | Solid State | 17 | 1st July 2004 10:20 PM |
