| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
Hi
This is my version of the class A BJT transistor buffer from Building a buffered Gainclone chip amp. ("Simple class A discrete buffer circuit"). I've omitted the DC blocking capacitor as my power-amp circuits (LM3886 units) already have them on their input. Will four 1.5uF MKT capacitors be sufficient for decoupling? It will be powered by a regulated +/-15V supply. Other than that, just running this design past people more expert than myself (there are a lot of you, trust me) to see if my version is sane and workable before building it. Regards... |
#2 |
Thought of another question: does it make any sense to separate power and signal grounds like I've done?
#3 |
Hi
I assume you simulated this circuit or at least adapted from something successful, but why the 1 amp BC639? Sure, this a class A output stage but what do you have in mind as a load and your planned quiescent current? If you need high output current capacity and hence will have high quiescent current and dissipation, the T0126 version BD139 is a lot easier to arrange cooling for. OTOH, if this is a marginal rating issue, BC327 or 8 are no slouch at this type of duty. A simple buffer will not have many layout issues provided your supplies are well filtered for the current required. Bypass requirements are pretty much related to that too. Not sure that placing the power input terminals central and running the 15V rails between the in and out signal terminals is a good idea, though. Generally, keep them well apart. Good luck and watch pinouts if trying substitutes!
regards |
#4 | |
Cheers |
#5 |
from my experience the 1.5µF caps should be way sufficient for local onboard buffering of the supplies. Especially when there is only an intermediate load to drive like 10k. Wouldn't run the buffer on much lower load impedances than that though without increasing the standing current, as the max out voltage before (current limit induced) clipping is 0.6V/R5*R_load. Also take a look at your voltage-regulators in combinination with the buffercircuit, and what else may be running off them. Voltage-regulators are amps too, so they have a chance of oscillating too if not treated with care. Agreed, its not very likely - haven't whitnessed an oscillating voltage-regulator-IC myself so far. But I also don't know what your voltage ragulation looks like. Hence the hint Regards |
#6 |
R3 and R9 seem like very high value for a bipolar input. Are you feeding this circuit from a DC coupled source?
The current source emitter load is around 5mA. This means, assuming an hfe of 300 (my guess), the base current of Q1 and Q4 will be circa 17uA. Across a 100k bias resistor this is a voltage drop of 1.6V - which translates directly into loss of headroom. Ugly. Most source equipment (CD player, iPhone/iPod)now days will easily drive 10k, and 5k is usually no problem. |
#7 |
Hi
I had a look at the Simple Discrete Buffer Circuit you referred to on the the Decibel Dungeon forum. Now I understand how the original poster came up with BC637 actually but it seemed he was throwing in absolutely anything that came to hand and could only have assessed the results by ear. The BC 547 would have been the appropriate choice. Really, that was one sure way to the bin for the project when you would still still have sub-optimal results after countless guesses at what combinations of parts might sound better before the smoke escapes. Bonsai gives you a good starter to designing a properly working circuit there. I would follow that up with the aim of learning to design your own electronic circuits and make part selections properly. Then you will be streets ahead of that guy's guessometry method and a lot happier with the sound.
regards Last edited by Ian Finch; 5th December 2010 at 04:22 PM. |
#8 | |||
I expect the input will be a CD player or the output of my PC's Xonar Essence sound card, so, no, not DC coupled. Thanks for all the info! Quote:
Do you recommend changing R5? Quote:
I just looked up the 547 and can get it locally through AZtronics. Looks like one of those parts available everywhere. Thanks for the help! |
#9 |
Try get the BC547B (or C). They have better Hfe (i.e. current gain) than the BC547A. See the datasheet here for how the grading works.
#10 | |
Elliott Sound Products - The Audio Pages (Main Index) Project 37 (The DOZ preamp) might look a little familiar in its topology and good to learn from.
regards |
| implement CCS on a BJT darlington buffer | gianmaria | Solid State | 36 | 29th September 2011 11:19 AM |
| BJT buffer design, can anyone help | tschrama | Solid State | 44 | 18th February 2009 06:52 AM |
| mos/bjt buffer in class A for headphone amp | sunrise | Headphone Systems | 7 | 20th October 2008 06:34 PM |
| BJT line buffer | hjelm | Solid State | 0 | 30th March 2004 12:33 PM |
| BJT Buffer Circuits? | JoeBob | Solid State | 20 | 9th July 2002 05:56 AM |
