Another easy to answer question that is above me. XLR vs Ground loop - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 8th December 2010, 12:40 PM   #11
Do not cut the PE of the CDP.
This could be potentially very dangerous !
Check your CDP. Is it double insulated? In which case it does not have a PE connection.
Does the hum only occur when CDP and PC are connected to your system. Do any other combinations of source components cause a milder version of your hum problem?
Could you draw a diagram of the interconnections between your various bits of equipment?
Have you read:
Audio Component Grounding and Interconnection
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 8th December 2010, 01:00 PM   #12
Bonsai is online now Bonsai  Europe
Bonsai's Avatar
Hello Intefeicio (hell of a name! hope I got it right - LOL)
I'm wondering if you have the mains supply to your gear aligned - by this I mean - are all the neutrals neutral and all the Live's actually lives and you dont' have a situation where one or more have L and N swapped.
Reason: If you have two pieces of gear connected to mains and the L & N's are swapped, its still 'safe' because the transformers provide isolatation from the mains, but, because the mains wiring is out of phase, you get very high common mode voltages appearing across the transformers. It only takes a very small amount of capacitive coupling to introduce all sorts of hum and garbage into a system.
Check it out and let us know if you find anything.
Good luck.
bonsai
Amplifier Design and Construction for MUSIC! http://hifisonix.com/
Old 8th December 2010, 01:27 PM   #13
BobEllis's Avatar
Can you use an optical connection for either the PC or CDP? That handily breaks the ground connection, although some have issues with optical's quality.
GainClone ground loop help DeanP Chip Amps 18 27th July 2011 09:02 AM
XLR Pin 1 question - chassis vs circuit ground HeadSh0T Pass Labs 25 30th September 2010 04:20 PM
ground loop Jamh Chip Amps 10 2nd November 2007 07:18 PM
hum,ground loop,earth loop problem with your answers please frank2395 Pass Labs 2 17th May 2005 06:46 PM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 12:55 PM
Copyright 1999-2017 diyAudio
