Audio Buffer 8 years after Audio Buffer 8 years after - diyAudio
Old 23rd November 2010, 05:02 PM   #1
PMA is offline PMA  Europe
PMA's Avatar
Default Audio Buffer 8 years after
I made some modifications of my 8 years old project, that can be seen in
Audio Buffer in english
Please forgive the old text, I would write it quite different today
Anyway - what are the current mods. I needed gain, so now I have the gain of +10x, i.e. 20dB. I decided to use Analog Devices ADA4898-1 opamp. This is a very nice part, which has very very low noise 0.9nV/rtHz, enough slew rate of 55V/us and very low distortion up to 100kHz.
Some distortion results measured just below clipping, and 100kHz square response in 400ns/div:
Old 24th November 2010, 11:34 AM   #2
Ian Finch is offline Ian Finch  Australia
Hi Pavel, Thanks for the update.
I have a question about the choice of the buffer and any advantage it has over single or parallel opamps, in the same position. Given that distortion levels in current opamp designs are also considerably lower, is there a particular reason to use it?
Ian
Old 24th November 2010, 05:36 PM   #3
PMA's Avatar
Ian,
please take into account that the plots are for gain 20dB, and 13Vp. Also, take into account CCIF 19+20kHz plot, and the time plot in 400ns/div.
For 5Vrms, I get 0.00068%, which is just the bottom I am able to measure, so in fact I do not know distortion at 5Vrms.
IMO buffering is very important.
1) you have high output stage idle current (15mA in this particular case)
2) you are able to drive any capacitive load, and resistor load down to 100ohm. This may sound useless, but rugged output IS important.
3) the output is immune to HF EMI interference
This goals are very important for my design philosophy, and sonic result is much better with buffer, to me. It just works
The opamp used is http://www.analog.com/static/importe.../ADA4898-1.pdf
to me this one of the best opamps for audio ever designed.
Old 24th November 2010, 06:43 PM   #4
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I agree with you Pavel 100%. Buffering is the key to good sound with Opamps, be the cable long or short, be the termination high impedance or low and this toutches only the surface. Another chip to watch is the LME49990 and the older but good LT1468.
I prefer an open loop buffer though, outside the feedback loop.
Old 24th November 2010, 06:44 PM   #5
iko is offline iko  Canada
iko's Avatar
Pavel, regarding the results above, into what load were the measurements made? Unless the same distortion applies into any load down to your 100 ohm example. I'd be most interested in distortion results into a typical load like headphones, for instance, 32-64 ohms, of an output voltage of about 3V p-p.
Old 24th November 2010, 07:28 PM   #6
PMA's Avatar
The measurements were made at 13Vp/3kohm. I can repeat them at 3Vp-p/32ohm.
I have one measurement at 0.5Vrms, but it just attacks my measurement limit.
Old 24th November 2010, 07:51 PM   #7
PMA's Avatar
These 2 measurements are for 50 ohm load at 3Vp-p
________________________
Edit: in fact the result is my soundcard again, and not the buffer. When I add the divider before the card input, I get 0.00062% at 3Vp-p/50 ohm, and I have reached my limits again. The 3rd image.
Old 24th November 2010, 08:10 PM   #8
PMA's Avatar
I have tried to tune the divider ratio in front of the card input (stepped attenuator with 1.5dB steps), this is the best I can get:
Old 24th November 2010, 08:16 PM   #9
iko's Avatar
Thank you Pavel. I think these are excellent distortion results.
And speaking of that, why would anyone try to do better? It really begs the question, why one would go to the trouble of building a tube headphone amp, hugely inefficient, with every kind of distortion higher than this one?
If we were to put into volts the amount of 3rd order distortion from the second graph, which looks to be around 105dB down from 3V p-p, it would amount to about 17uV p-p.
May I ask what sound card you're using for these measurements?
Old 24th November 2010, 08:30 PM   #10
PMA's Avatar
The soundcard is a cheap M-Audio FastTrack USB. I have to run it 6-12dB under full scale input to get lowest distortion. Also, I often have to use input signal transformer, to convert card input signal to balanced - this is the only way how to keep low distortion of the card at higher frequencies, and to avoid ground loop.
Audio Buffer 8 years afterHide this!Advertise here!
Visionaries: Audio & speaker tech in 10 years?? LineSource Multi-Way 36 1st July 2013 09:17 PM
Audio buffer amplifier cumesoftware Solid State 28 16th June 2008 09:41 AM
audio buffer layout digi01 Chip Amps 71 7th October 2006 05:34 AM
Article about the evolution of audio suff the last 100 years? Bricolo Everything Else 16 17th May 2004 12:24 PM
Copyright ©1999-2017 diyAudio
