Go Back   Home > Forums > Source & Line > Analog Line Level
Old 22nd November 2010, 08:30 PM   #11
Obe1 is offline Obe1  United States
The 8 volt can come from a zener... the current needed is essentially zero and the -0.3 from a germanium diode (as I used) although I can't see why just resistive dividers couldn't be used if the supplies to the opamp are stable. Tie the gates to the -0.3v via say 2.2meg resistors... that put's both FET's off. Then use the switch to overide that by feeding the 8 volts via say 220k
This looks very good and uses less parts than what I was thinking about.
I can't wait to try this out. Hope my local toy store has what I need to test this baby out.
Thanks again Mooly!
Old 22nd November 2010, 09:14 PM   #12
Hi Mooly,
Please verify the voltage polarities for me. I thought an n-channel JFET would need 0.0 to say plus (+) 0.3 volts to turn on and a minus (-) 6.0 to (-) 8.0 volts to turn off.
Old 22nd November 2010, 09:35 PM   #13
Banned
That's an N-channel jfet? That would make the control voltage polarities in the original diagram correct. If you take the gate of an N-channel jfet more than about 0.5V more positive than the source, then the gate-channel diode will conduct.
w
Old 22nd November 2010, 10:26 PM   #14
Thanks wakibaki,
I got twisted around when I looked at Mooly's original schematic that shows gate control voltages of +0.3 volts and -8.0 volts.
Old 22nd November 2010, 11:08 PM   #15
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
You might find the JFET a bit tricky to source, its a Sony part. Doug Self's book 'Small signal audio design' has a whole chapter dedicated to signal switching circuits and goes into some depth with JFET switching arrangements. He prefers to use the J112 which is very widely available.
When a measure becomes a target, it ceases to be a good measure. C.A.E. Goodhart
Old 23rd November 2010, 12:08 AM   #16
Thanks abraxalito,
It's nice to have choices!
I'll also say that the more I try to learn about JFET's the more I get confused. For example, here are specs for several popular n-channel JFET's that might be candidates in this application:
Datasheet for 2N3819: Vgs (off) = minimum not stated, maximum +8.0 Volts
Datasheet for BF245C: Vgs (off) = minimum -0.5 Volts, maximum -8.0 Volts
Datasheet for J112: Vgs (off) = minimum -1.0 Volts, maximum -5.0 Volts
So why do some of these have a positive Vgss (off) value and others are negative?
Old 23rd November 2010, 12:17 AM   #17
abraxalito's Avatar
There's a very simple answer to this question Datasheets sometimes contain errors - you've found one in the Fairchild datasheet for the 2N3819. Onsemi's is just as bad. The correct (and most comprehensive) data is found in Vishay 2N3819
Old 23rd November 2010, 12:32 AM   #18
Thanks again abraxalito,
From now on I'll check the datasheet's from multiple manufacturers on any given part.
Old 23rd November 2010, 12:38 AM   #19
abraxalito's Avatar
Good move. My working assumption is this - the datasheet containing the most details is going to be the source datasheet, thus the least susceptible to errors. The others will be copies.
Old 23rd November 2010, 06:18 AM   #20
Calvin is offline Calvin  Germany
Calvin's Avatar
I wouldnŽt recommend JFETs as swiching devices, especially not those named here. The 2N3829 for example features an Rds(on) of 150Ohms, the J112 50Ohms. What You want is a as low and linear-over-signal-voltage as possible device. IŽd rather opt for a low Rds(on) MOSFET instead or a dedicated switch or multiplexer like the ADG- and DG-series of AnalogDevices or the 460x-series (and others) of Maxim.
jauu
Calvin
Volume / Source selector - open source project ? AuroraB Analog Line Level 22 22nd September 2012 02:21 PM
Arduino based Input Selector for preamp _atari_ Analog Line Level 5 30th June 2010 02:42 PM
source selector mnr102 Multi-Way 0 24th February 2008 11:11 PM
how to make a audio source selector? no183 Analog Line Level 7 28th November 2007 11:36 AM
Relay based source selector. Help needed! MASantos Chip Amps 9 8th August 2007 11:28 PM
Copyright ©1999-2013 diyAudio
