5-BAND EQ: Constant Q or conventional topology? - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 22nd November 2010, 08:58 AM   #1
Send a message via MSN to -_nando-_ Send a message via Skype™ to -_nando-_
Question 5-BAND EQ: Constant Q or conventional topology?
Hi there!
I'd like to know your valued opinion about which type of equalizer would be best for a 5-Band control. I particulary like the Constant-Q design, but I'm not sure if it would be adequate for a 5-band EQ.
Frequencies are planned to be 64hz, 250hz, 640hz, 4k and 12khz. It's intended for small / medium P.A. applications. Suggestions are welcome!
Thank you.
Best Regards!
Old 22nd November 2010, 09:47 PM   #2
Is this equalizer going to be parametric or graphic? Because if you're going for a parametric EQ, you don't need to decide between constant-Q or conventional-Q! Parametrics (at least fully parametric) equalizers feature a knob that regulates how much Q will be present. This also has the side benefit of allowing you to dial in a particular frequency and cut it with a very low Q to control feedback, very useful for the P.A. application you mentioned.
Old 23rd November 2010, 12:19 PM   #3
Hello diymixer, thanks for your input.
It will be a graphic equalizer, unfortunatelly I have room for only 5 control potentiometers.
So, constant-Q or conventional? In case I use constant-Q, should I make the Q factor wide enough to cover the entire "gap" between the centered frequencies?
Cheers!
Constant Q parametric equalizers (SVF topology) frickecello Analog Line Level 8 25th September 2011 02:19 PM
3 band eq with ballance and gain jamie1107 Solid State 3 28th July 2011 01:52 AM
Constant Directivity Horn EQ Horizons Multi-Way 4 19th December 2008 11:41 AM
Constant directivity EQ Saurav Multi-Way 11 19th May 2008 02:41 AM
Copyright 1999-2017 diyAudio
