| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#21 |
Guys,
I just completed a couple more mods to my Jolida. I put .22 Sprague caps on the power caps as a bypass & I put in a pair of Caddock resistors. WOW! A big increase in clarity from the resistors and an increase in bass from the caps. Then I remembered that someone on another forum said that the 12au7's had less output, so I put in a NOS set of Seimen's - the gain went down to closer to what the other components are. The resistors are a PIA to install so I only put in one set. Maybe I will feel up to putting in the other set next week... but so far - so good! I will post again when I do the other set. |
#22 |
Wire Nut,
Any reason you used .22uf caps for bypassing the power supply caps? Did you just put two of them in? Also what voltage are those? I'm looking to mod my PSU section next and I've notice others have used 1uf caps. I'm also looking for what type of diodes to buy to replace the ones onboard as well as that seems to be a pretty common modification. Also which resistors did you replace? Thanks for the help! |
#23 |
I used .22 because I had a bunch around from my AR-XA mod, I actually installed four of them, they happen to be 600v. ... but I did order some 1.0 from the net & will install one on the bigger cap as there is still one that does not have an extra cap yet.
#24 |
For anybody that is looking to upgrade their JD9, I made a step by step guide to upgrading the caps, opamps, tubes, and installing dampening material. I hope this guide helps those that are looking to upgrade.
Comments and suggestions welcome! ![]() Step by Step guide
#25 |
Good job on the pics and text of the mods. I've got a jd9 also. If I do the mods, what improvements could I expect to hear?
#26 |
I have mine modded with CC MR coupling caps, Amtrans AMCH loading caps(not for a novice), and gold lion tubes. Bypassed, or upgraded PS caps and Vampire copper RCA jacks are up next.
IMO, it's a fantastic phono pre. Very versatile due to the adjustable loading switches and high available gain. It also sounds very good, clean and very dynamic. My only complaints are the blinding LED(which will be fixed soon, too) and lack of rumble filter.
"If it measures good and sounds bad, -- it is bad. If it sounds good and measures bad, -- you've measured the wrong thing." Daniel R. von Recklinghausen |
#27 | |
The biggest difference was a HUGE increase in clarity. Luckily, it did not make the sound "too bright" but rather maintained the musicality while clearing up the soundstage. The original sound compared to the upgrade can be described as "muddy." The JD9 really does benefit tremendously by the upgrades and I think it take it into the range of phono preamps that cost $1,000's of dollars. |
#28 |
I did quite a few mods to mine, ditto to above, the clarity is really top notch, it is actually "warmer" meaning more tube sound, the imaging and soundstage are better as well. Here is what it looks like now.
Turntable Forum • View image - V-Caps |
#29 |
From what I can see(need new glasses), it appears there's already a 12K resistor in series with the LED.
#30 |
I intend to mod my JD9 which I bought from a seller at Audiogon. Before I carryout this mod, I need to change the operating voltage from 120V 60 HZ to 220V 50HZ. Can anyone advise me how I should get about on doing the power conversion. I have tried to get the information Jolida USA, unfortunately they have not responded to my request.
| Cambridge Audio A1 mk3 upgrade mods | Honda Z50M | Chip Amps | 24 | 30th September 2012 10:58 AM |
| Proac Studio200 - Upgrade mods help needed | stu.dio | Multi-Way | 2 | 21st November 2008 02:19 AM |
| JBL 300.4 amp upgrade/mods | ahmisuhairi | Car Audio | 6 | 26th September 2007 06:34 AM |
| Better Sounding Direct Replacement For OPA OP37 In Jolida JD9 Phono Stage | XTRprof | Analogue Source | 5 | 30th June 2007 10:00 AM |
| jolida JD100H upgrade | maya1 | Digital Source | 0 | 30th April 2004 04:10 PM |
