Jolida JD9 Upgrade/Mods Clarification. - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 28th March 2011, 01:52 AM   #11
Is there a reason why you do not just solder the new capacitors to the same points as the original ones were removed from, albeit on the back of the PCB?
Old 28th March 2011, 02:52 AM   #12
you sure can, if they fit. the idea with soldering to the tube output and the output wire is to remove some of the pcb in the path.
Old 27th April 2011, 03:16 AM   #13
Thanks for the information.
I have now replaced all six op amps as suggested, with noticeable improvement.
I now have capacitors to change but I am more used to electrolytic capacitors which are polarity conscious, are these capacitors not?
I just wanted to confirm before doing something catastrophic.
Old 11th August 2011, 12:01 AM   #14
Hi guys,
Based on the Audio Circle post I am about to attemp these mods, I shold be picking up my brand new black JD9 from the local Needle Dr tomorrow!!!
Jolida JD9 Upgrades
Obbligato 1.5 caps
Vishay bypass caps on above
Tubes (Ei vintage, Tele smooth plate, or Mullard long plate- one of these should be the cat's meow with the new cart)
B-Quiet with carbon/copper strands glued on top (damping)
Quiet Kote on top (damping)
Parts Express on bottom (damping)
Gold Alloy wire to replace key wires
Neotech wire to replace long run to circut board
Op-Amps
Power cable (very tasty Western Electric that is burning in at this moment)
Why all this hassle? My PS Audio does not have enough gain for the Denon 103r that I just put in a rosewood body!
Old 24th August 2011, 11:00 PM   #15
Thanks for the pictures earlier in the thread showing where to solder the caps on the bottom of the board. I joined this board because I would like to mod my Jolida as well.
Question for you guys running the ClarityCap MR's, do you need to attach them in the fashion that the guy did from the other thread? I'm not really sure what the "sticky plate" things are, and there appears to be a zip tie connecting the two. Mine are on there way, I've had a stock unit that I've just rolled some tubes in for the last few months. Looking forward to getting some upgrade, my modded 302b is pretty special!
Thanks.
Old 1st November 2011, 01:01 AM   #16
midfi is offline midfi  United States
my question is what can be done to dim down this 20 gigawatt LED on the front of it!?!?!?
it lights up the room when the lights are out!
By 3 methods may we learn wisdom: 1st by reflection which is noblest, 2nd by imitation which is easiest, and 3rd by experience which is the bitterest.
Old 1st November 2011, 04:34 PM   #17
tape/marker pen?
Old 2nd November 2011, 11:08 PM   #18
Originally Posted by nathanjh13 View Post
tape/marker pen?
tried a felt tip marker but the ink wont stick. Maybe it's glass and not plastic. Didn't wanna look "ghetto" with a piece o' tape on da front!
Old 4th November 2011, 09:32 AM   #19
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
LoL - now that is one bright LED. :-0
Can you show a picture of the LED on the inside and the wires to it? Its quite easy to insert a series resistor to dim is down.
For starters try a 2.2k, if thats still too bright, go to a 10k.
bonsai
Amplifier Design and Construction for MUSIC! http://hifisonix.com/
Old 5th November 2011, 08:27 PM   #20
I'll take the lid off in a few days and snap a pic.
Cambridge Audio A1 mk3 upgrade mods Honda Z50M Chip Amps 28 1st March 2014 02:08 PM
Proac Studio200 - Upgrade mods help needed stu.dio Multi-Way 2 21st November 2008 02:19 AM
JBL 300.4 amp upgrade/mods ahmisuhairi Car Audio 6 26th September 2007 06:34 AM
Better Sounding Direct Replacement For OPA OP37 In Jolida JD9 Phono Stage XTRprof Analogue Source 5 30th June 2007 10:00 AM
jolida JD100H upgrade maya1 Digital Source 0 30th April 2004 04:10 PM
Copyright 1999-2017 diyAudio
