Go Back   Home > Forums > Source & Line > Analog Line Level
Old 13th November 2010, 01:38 AM   #11
Bonsai is offline Bonsai  Taiwan
Bonsai's Avatar
"Output current is limited in most opamps anyway (OPA2134, LM833, TL071 all indicate this on the datasheet), so a short shouldn't be fatal should it? "
Most monolithic op-amps can take an indefinite short circuit on the output without damage or degradation. You need to check the data sheet though. They will run hot in this condition, so its generally a thermal issue, rather than an electrical over stress (EOS) issue.
bonsai
Amplifier Design and Construction for MUSIC! http://hifisonix.com/
Old 13th November 2010, 01:11 PM   #12
Originally Posted by DF96 View Post
A transformer will also, to some extent, transform the capacitive reactance although leakage inductance and transformer resonances will confuse the issue.
Yes, I dropped by Maplin this morning and got them to let me use their fancy DMM to measure L and C in the transformer.
Plugging the values into LTspice, it looks like the HV winding(s) will not be suitable for an output. The AF response starts to become dependent on cable characteristics with more than a few meters of toilet-venue grade cable. So a step-up configuration is ruled out anyway.
Thanks for the responses, it's helped me in thinking this through. Especially to Bonsai for telling how to do it. It may still come in handy one day.
Capacitor in series - Resistor across ? McIntosh Man Tubes / Valves 4 6th March 2010 01:26 PM
resistor in series or parallel mace Multi-Way 4 21st January 2008 09:21 PM
Series resistor placement angsuman Multi-Way 5 15th July 2006 12:06 AM
Adding series resistor to sub regal Subwoofers 6 17th August 2005 12:53 AM
Eliminating capacitor in amplifier series feedback loop Hennie Solid State 17 13th December 2004 11:26 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
