SSM2019 with unbalanced input
Old 9th November 2010, 05:16 AM   #1
Steinberg is offline Steinberg  Poland
Default SSM2019 with unbalanced input
Hello
I've got the question about preamp I found. Thats project:
http://www.diyaudio.com/forums/attac...1&d=1289283154
SSM2019 with unbalanced input-ssm2019-preamp-1-jpg
So, How to modify this preamp to reach unbalanced input with +/- 15V supply? Is it possible?
This should work as non inverted preamp.
How to connect -IN of SSM2019?
Thx
Old 9th November 2010, 06:11 PM   #2
zdavesf is offline zdavesf  Canada
The schematic you are looking at is really designed for balanced inputs (seen this IC on a lot of microphone preamps). The IC is actually 3 opamps configured as an instrumentation amplifier. To make it work singled ended you can simply ground "A2" input however you will drastically reduce your Common mode rejection and degrade your signal, Not advisable for a design. You can always use an opamp input for your pre. Is there any reason you want to use this circuit?
Dave
we all have to start somewhere...
Old 9th November 2010, 06:53 PM   #3
I'll draw & public all my device tonight.
I try to build portable mixer for tv/radio.
OK; but please wait for schematic...
Then we will talk about all my faults
SSM2019 with unbalanced inputHide this!Advertise here!
Unbalanced to balanced input conversion? SQLGuy Solid State 53 19th October 2009 01:39 AM
Wiring for XLR input on unbalanced amp Arx Chip Amps 3 16th April 2007 06:57 AM
converting and unbalanced in into a balanced input joyfulstudios Parts 2 12th June 2005 12:41 AM
Converting balance to unbalanced input diyman Solid State 4 7th March 2004 09:16 PM
Unbalanced input SOZ? paulb Pass Labs 5 27th September 2001 05:01 AM
