Adding balancing transformer to preamp, signal loss
Old 8th November 2010, 01:54 AM   #1
marlouv is offline marlouv  Australia
Default Adding balancing transformer to preamp, signal loss
I have a nice and fine preamp build for a PVDF pickup, amplifying the signal to more than usable levels.
After losing the battle with 60hz hum, I have inserted a passive DI between the preamp (circuit) out and output jack. (no 20dB cut, otherwise identical, without the ground cut switch)
that is a 1,000uF cap, isn't it..
After putting it all back together, working fine, except the signal fell down a mineshaft, and all the gain I use to be able to hear it, only just, is silly. Is it normal for passive balancing to cut the level so much?
Is it a case for amplifying the signal again, before or after the transformer?
Old 8th November 2010, 07:46 PM   #2
amz-fx is offline amz-fx  United States
The output impedance of the jfet booster is quite high. It is running out of drive when trying to swing the signal through the transformer. You could use a common emitter buffer after the jfet to add some drive capacity... it only adds 2 parts.
Collector to +9v and the emitter is the output; base is the input from the jfet's drain. See attachment.
This should be enough drive...
-Jack
Old 9th November 2010, 12:54 AM   #3
Made the changes, but still no cigar. Level slightly higher, is it safe or sane to lower the emitter resistor? I'll give that a go, and then strip the circuit back to see if something hasn't gone wrong up the line.
Old 9th November 2010, 02:00 AM   #4
Came up with a bad TRS jack, only half the balanced signal was getting through, and that's going to be quiet.. All working now, sorry about that, but thanks for your help Jack.
tops off
Adding balancing transformer to preamp, signal lossHide this!Advertise here!
tube preamp: adding headphone out then_dude Headphone Systems 10 19th July 2012 11:02 AM
adding xtra transformer to cdp need help! crippledchicken Solid State 8 22nd September 2004 01:30 AM
Adding more inputs for my preamp bonsai171 Solid State 1 11th March 2004 10:59 PM
Benefit of adding transformer to electronically balanced mic preamp? cdwitmer Solid State 5 31st August 2003 07:50 PM
DAC out to preamp = signal loss? Jay Tubes / Valves 2 17th April 2003 11:36 PM
