Need circuit, 6,12,18,24db attenuator - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 27th October 2010, 04:51 AM   #1
Default Need circuit, 6,12,18,24db attenuator
Need a circuit for an attenuator with four steps,
to knock down the Line Level to mic. level for my camcorder.
I have 4 SPST toggle switches in the box, and
need 6, 12, 18, and 24db attenuation. I am thinking,
some sort of L-Pads but short out some of them?
Have lots of resistors 100-300 ohms, etc. in the drawer,
and lots of 6.8K and 10k etc
I can't seem to solve this... duh.
Old 27th October 2010, 05:32 AM   #2
well -6db is half the voltage so 2 equal value resistors in series, one end is input the other end is ground and the middle is 6db down.
then if you split the bottomn resistor in equal values again and take the signal from that point it will be half again or 12db down, continue to get -18db and -24 db.
remember -6db is half voltage, -12db is quater -18 is 1/8th and -24 is 1/16th
so if the botomn resistor is 1ohm what are the rest?
Old 27th October 2010, 06:41 AM   #3
tomchr is offline tomchr  Canada
tomchr's Avatar
Or build four 6 dB attenuators in series. Of course, they'd all be loading one another... Tricky business. I think T networks are commonly used for this - at least in the RF world.
Multisync's idea is the one commonly used for audio. It's essentially a crude potentiometer - or voltage divider.
Old 27th October 2010, 07:28 AM   #4
johnferrier's Avatar
attenuation with better than 0.01 dB accuracy (= overkill)
Michael Gazzaniga - "The arts are not frosting but baking soda."
Old 27th October 2010, 07:51 AM   #5
Roushon is offline Roushon  India
Default A possible solution
Attached is a possible solution. But you need SPDT switch and possibly some
new resistors to avoid a long series connection.
Roushon
S. Roushon
Old 27th October 2010, 03:53 PM   #6
AndrewT is online now AndrewT  Scotland
use a -6dB T pad attenuator.
The load impedance must match the attenuator impedance. This is easiest achieved by having a removable load on the output that can be swapped to suit different Rin values.
I built up 600r T attenuator for my 12 switch 0dB to -61dB attenuator in steps of 0.05dB. Great for accurately comparing different voltages, eg. input and output of a power amp.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 27th October 2010, 07:25 PM   #7
a few problems you may run into,
what is the input Z of your mic input? 600ohms?
What is the level of the mic input 1-10 millivolts?
what is the output Z of your line device? 10Kohms or 1k ohms
what is the line out put level? 100 millivolts or 1volt?
you will have to know some of these values or make some guesses to get the attenuator to do what you want
Old 28th October 2010, 01:00 AM   #8
Banned
...AND the source impedance. Each attenuator pad input and output impedance must match the source and load impedances. Otherwise each attenuator stage looks back into an impedance which is modified by the source impedance.
You can design a single T- or pi-attenuator of any attenuation to match between any source impedance and any load impedance.
You can design a string of switched series T- or pi-attenuators to provide any desired attenuation steps between matched source and load impedances.
You cannot design a string of switched series T- or pi-attenuators to provide any desired attenuation steps between unmatched source and load impedances, as the second pad in the string may see the first pad as a source and vice versa. To maintain the calculated attenuation each pad must match its source impedance. If this is not the same as the load (output impedance of the preceeding pad) then the attenuation is affected. Of course if the only mismatch is to the source and each pad that is interposed has equal input and output impedances then this pulls the seen impedance closer to the correct value. This is why pads are sometimes used in RF design to minimise the impact of any mismatch.
For instance, you can design 6, 12, and 24dB L-attenuators between 50k and 50k. You can now switch them into and out of circuit (using a DPDT switch per stage) to give 0, 6, 12, 18, 24, 30, 36 and 42 dB attenuation (using a binary switching pattern) and both source and load will see 50k looking into the attenuator (or looking into each other) regardless. Each DPDT switch is wired to switch in an attenuator or a short. Make the source and load impedances different and the whole thing falls apart. It may well be possible to design a complicated arrangement of switches and resistors to achieve the desired result, but each pad must be modified in the switching to change its output impedance to be identical to its input impedance and this will change its attenuation which much again be corrected for.
If the source and load impedances are different you need to design 7 different T- or pi- pads (to match the range given above) and switch just one into circuit. Or modify the source or load impedance (or both) with a series or parallel resistor to make them identical (and accept any losses) and match the attenuator to this.
In this case the power is irrelevant as it is small enough, being line level, to be ignored.
This is all a bit nit-picking, you may well get away with something like this, or look at the link for values:
Attenuators : AMPLIFIERS AND ACTIVE DEVICES
w
Old 28th October 2010, 04:54 AM   #9
Default Attenuator
The attenuator circuit has input and output impedances 10K. It works fine in between my
cd-player (Marantz cd5003) and my amp which I built using LM3886. Each stage
has matched impedance with the previous and the next stage. This is the reason
why it has got the unusual resistor values. Actually it is part of the attached more
advanced attenuator.
Roushon
S. Roushon
Old 28th October 2010, 05:23 PM   #10
Katman is offline Katman  Italy
-30dB:
22k in series (between line out and mic in)
680 Ohm from mic input to ground.
Gianluca
Building a Hafler XL-10 Excelinear attenuator circuit HaflerFreak Solid State 4 9th September 2010 12:02 AM
who makes 18" x 12" x horn 3-w box??? mastadon Full Range 2 29th October 2009 09:31 PM
12 vdc to 18 vdc isolated P-P jamesrnz Power Supplies 89 4th February 2009 04:36 PM
12 step 10k attenuator problem vdi_nenna Everything Else 2 26th July 2005 08:10 PM
6,12,18,24db Xovers: General Q's Evan Robinson Multi-Way 1 23rd July 2005 09:06 AM
Copyright 1999-2017 diyAudio
