Need circuit, 6,12,18,24db attenuator Need circuit, 6,12,18,24db attenuator - Page 3 - diyAudio
Old 22nd March 2013, 09:04 PM   #21
GoatGuy is offline GoatGuy  United States
GoatGuy's Avatar
Then there's another method... having a series of shunt resistors that each add 6 dB ... of attenuation. The only caveat is that they have to be turned ON in sequence "conceptually left to right"...
R0 (first series resistor) = 1000 ohms
R1 (first shunt resistor) = 1000 ohms
R2 (second shunt resis.) = 500 ohms
R3 (third shunt resistor) = 250 ohms
R4 (fourth shunt resist.) = 125 ohms
So, with no resistors shunted ... you get the 1K series resistor and the 10K load impedance resulting in an innocuous -0.8 dB drop... almost nothing. Then as each of the resistors is shunted in in turn, additional attenuation, in 6 dB steps.
Kind of what you're looking for?
GoatGuy
Old 22nd March 2013, 09:40 PM   #22
GoatGuy's Avatar
Default And now for a little circuit diagram...
is there a diagram? Hard to tell... let me see
Need circuit, 6,12,18,24db attenuatorHide this!Advertise here!
Building a Hafler XL-10 Excelinear attenuator circuit HaflerFreak Solid State 4 8th September 2010 11:02 PM
who makes 18" x 12" x horn 3-w box??? mastadon Full Range 2 29th October 2009 08:31 PM
12 vdc to 18 vdc isolated P-P jamesrnz Power Supplies 89 4th February 2009 03:36 PM
12 step 10k attenuator problem vdi_nenna Everything Else 2 26th July 2005 07:10 PM
6,12,18,24db Xovers: General Q's Evan Robinson Multi-Way 1 23rd July 2005 08:06 AM
Copyright ©1999-2017 diyAudio
