compressor diy
compressor diy
Old 25th October 2010, 08:51 AM   #1
bigredlevy is offline bigredlevy
Default compressor diy
I soldered up this circuit today to find that it is utterly useless.
An output of 70mV from line level input.
bah! what a waste of time
I'm keen on DIY recording gear, and I want some compressors to run as inserts on my mixing console.
can anyone suggest a simple circuit?
I prefer veroboard, as I have no experience in making PCBs.
Old 25th October 2010, 02:24 PM   #2
mickeymoose is offline mickeymoose  Canada
What a waste of time? You learned something!
Interesting circuit, but it will not do to send clean audio to a mixing console! Low distortion compressors can not be build with 10 parts.
Go to thatcorp.com and check on their app notes on signal processing (parts THAT2180 and THAT4301)
Old 26th October 2010, 08:50 AM   #3
Default cheers
Thanks a lot mickeymoose. That site has a pretty comprehensive array of designs. I'm looking at the "one knob squeezer". http://www.thatcorp.com/datashts/dn125.pdf
It is slightly going against my original idea. I want to design simple veroboard diagrams using easy to find, straight off the shelf parts. I want to compile a bunch of simple audio circuits so that other people can reproduce them easily.
This is my first try Levy Sound Design: Electret Condenser Microphones
I'm currently working on a veroboard design of the "flatline compressor"
Old 28th October 2010, 05:57 AM   #4
audi0 is offline audi0  Australia
I remember seeing this compressor circuit in a Elektor circuit book, don't know if this circuit is worth a try?
Old 28th October 2010, 10:27 AM   #5
That is exactly the circuit I made the other day.
I must have checked it twenty times trying to find something wrong with it, but even on my guitar amp, it attenuates the level way too much.
I guess you don't get anything for nothing. looks like passive isn't the way to go.
Old 2nd November 2010, 04:12 PM   #6
-_nando-_ is offline -_nando-_  Brazil
Send a message via MSN to -_nando-_ compressor diy
Compressors using Led / LDR use to work very well.
Old 2nd November 2010, 04:36 PM   #7
LAJ is offline LAJ  United States
Have you tried the Signetics NE570? It can be configured as a compressor or an expander. Its a two channel device also. It worked very well for me.
Old 8th November 2010, 07:58 PM   #8
amz-fx is offline amz-fx  United States
A couple of easy designs on my web site: SSM2166 Compressor
Easy is not a substitute for top audio quality but you can give it a try - use v2. It's going to be less noisy than the NE570. Small Bear Elec has some of the chips for sale.
regards, Jack
Old 28th November 2010, 06:30 PM   #9
C13 is offline C13  Indonesia
regards, Jack
whether the compressor can be applied with Daw ... for example be applied to mixdown from NUENDO 4..???
best regardds
compressor diyHide this!Advertise here!
Simple compressor PeteMcK Elektor 4 25th August 2009 01:30 AM
compressor Faiirchild 670 DIY plinio Tubes / Valves 1 26th December 2008 02:28 PM
Compressor diy XXLPeanut Instruments and Amps 5 14th June 2006 10:55 PM
DIY air compressor. help needed peterr Everything Else 4 8th September 2005 01:10 PM
compressor schematic JBL Solid State 18 21st October 2002 11:00 PM
