Resistors valus for shunt stepped attenuator?
Old 24th October 2010, 02:25 PM   #1
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Default Resistors valus for shunt stepped attenuator?
I want do do a shunt stepped attenuator 10K with 23 steps, the question: is this table showing the right values?
Step 1, Attenuation = Infinity dB, Rx = 10000 ohms, Ry = 0 ohms.
Step 2, Attenuation = 75 dB, Rx = 10000 ohms, Ry = 2 ohms.
Step 3, Attenuation = 72 dB, Rx = 10000 ohms, Ry = 3 ohms.
Step 4, Attenuation = 69 dB, Rx = 10000 ohms, Ry = 4 ohms.
Step 5, Attenuation = 66 dB, Rx = 10000 ohms, Ry = 5 ohms.
Step 6, Attenuation = 63 dB, Rx = 10000 ohms, Ry = 7 ohms.
Step 7, Attenuation = 60 dB, Rx = 10000 ohms, Ry = 10 ohms.
Step 8, Attenuation = 58 dB, Rx = 10000 ohms, Ry = 13 ohms.
Step 9, Attenuation = 56 dB, Rx = 10000 ohms, Ry = 16 ohms.
Step 10, Attenuation = 54 dB, Rx = 10000 ohms, Ry = 20 ohms.
Step 11, Attenuation = 52 dB, Rx = 10000 ohms, Ry = 25 ohms.
Step 12, Attenuation = 50 dB, Rx = 10000 ohms, Ry = 32 ohms.
Step 13, Attenuation = 48 dB, Rx = 10000 ohms, Ry = 40 ohms.
Step 14, Attenuation = 46 dB, Rx = 10000 ohms, Ry = 50 ohms.
Step 15, Attenuation = 44 dB, Rx = 10000 ohms, Ry = 63 ohms.
Step 16, Attenuation = 42 dB, Rx = 10000 ohms, Ry = 80 ohms.
Step 17, Attenuation = 40 dB, Rx = 10000 ohms, Ry = 101 ohms.
Step 18, Attenuation = 38 dB, Rx = 10000 ohms, Ry = 127 ohms.
Step 19, Attenuation = 36 dB, Rx = 10000 ohms, Ry = 161 ohms.
Step 20, Attenuation = 34 dB, Rx = 10000 ohms, Ry = 204 ohms.
Step 21, Attenuation = 32 dB, Rx = 10000 ohms, Ry = 258 ohms.
Step 22, Attenuation = 30 dB, Rx = 10000 ohms, Ry = 327 ohms.
Step 23, Attenuation = 28 dB, Rx = 10000 ohms, Ry = 415 ohms.
Thanks for help.
Old 24th October 2010, 02:31 PM   #2
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Parallel Resistor Calculator Find Optimum Resistors to Place in Parallel to Create Non-Std Value - PARALLELRESCALC - TI Tool Folder
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 41 pcb's in interest.
Old 24th October 2010, 02:35 PM   #3
Thanks for help PA, my posted table are the rights values? I understand that you posted the TI link to get exact values right?
Old 24th October 2010, 04:26 PM   #4
wakibaki is offline wakibaki  United Kingdom
Banned
Here's the attenuation with R1 as series element followed by R2 to ground, signal taken at junction of R1, R2.
W
Old 24th October 2010, 04:57 PM   #5
So it's OK the values for 23 steps 10K shunt, right?
Old 24th October 2010, 05:02 PM   #6
Banned
Here's the exact values:
w
Old 24th October 2010, 05:07 PM   #7
Thank you wakiwaki, I do a mistake step 23 Ry without resistor only Rx resistor 10K in series.
Old 25th October 2010, 02:10 PM   #8
Now the Shallco 23 stepped attenuator is with these resistors & sounds very good:
Step 1, Rx = 10000 ohms, Ry = 0 ohms.
Step 2, Rx = 10000 ohms, Ry = 2 ohms.
Step 3, Rx = 10000 ohms, Ry = 3.6 ohms.
Step 4, Rx = 10000 ohms, Ry = 6.8 ohms.
Step 5, Rx = 10000 ohms, Ry = 13 ohms.
Step 6, Rx = 10000 ohms, Ry = 22ohms.
Step 7, Rx = 10000 ohms, Ry = 39 ohms.
Step 8, Rx = 10000 ohms, Ry = 68 ohms.
Step 9, Rx = 10000 ohms, Ry = 120 ohms.
Step 10, Rx = 10000 ohms, Ry = 180 ohms.
Step 11, Rx = 10000 ohms, Ry = 270 ohms.
Step 12, Rx = 10000 ohms, Ry = 360 ohms.
Step 13, Rx = 10000 ohms, Ry = 510 ohms.
Step 14, Rx = 10000 ohms, Ry = 820 ohms.
Step 15, Rx = 10000 ohms, Ry = 1K1 ohms.
Step 16, Rx = 10000 ohms, Ry = 1K6 ohms.
Step 17, Rx = 10000 ohms, Ry = 2K4 ohms.
Step 18, Rx = 10000 ohms, Ry = 3K ohms.
Step 19, Rx = 10000 ohms, Ry = 4K7 ohms.
Step 20, Rx = 10000 ohms, Ry = 6K8 ohms.
Step 21, Rx = 10000 ohms, Ry = 9K ohms.
Step 22, Rx = 10000 ohms, Ry = 15K ohms.
Step 23, Rx = 10000 ohms, Ry = without resistor / not connected
There is a mistake or something wrong?
Old 26th October 2010, 01:04 PM   #9
Question Please help?
Please help?
Old 26th October 2010, 01:36 PM   #10
Banned
I'm not quite sure what the problem is.
You could try these numbers:
If you want a stage with NO attenuation, then try this:
w
Resistors valus for shunt stepped attenuator?Hide this!Advertise here!
Resistors for Stepped Attenuator stl Parts 43 2nd August 2016 04:04 PM
Calculation of stepped shunt attenuator Mick_F Chip Amps 2 25th January 2014 10:49 AM
Calculating a stepped attenuator resistors values... youyoung21147 Parts 3 13th June 2005 07:07 AM
Carbon film vs metal film resistors in a stepped attenuator? G Tubes / Valves 17 22nd August 2004 12:22 AM
Shunt volume controll (scaling the shunt resistors) Freddie Solid State 7 30th August 2001 09:47 PM
