Resistors valus for shunt stepped attenuator?
Old 31st October 2010, 01:43 PM   #21
post 13 shows values for 100M and 100k.
Borbely's 1M lies between these example values.
regards Andrew T.
Old 31st October 2010, 03:06 PM   #22
merlin el mago is offline merlin el mago
merlin el mago's Avatar
So is between -20.00001dB & -20.08dB instead the -20dB calculate at the stepped attenuator, not bad at all!!!!!
Old 31st October 2010, 04:08 PM   #23
and part of the reason for the very low error is that the ratio of Rin:Rs is >=1M:2k5
Instead of the more usual 10:1 or 20:1 ratio you have >=400:1
The error also becomes less as attenuation is increased (lower Rs) and conversely becomes higher as attenuation is reduced.
Watch that 1M. we have moved away from high input impedances as valve gear has become less common.
We usually find that lower input impedances result in less interference and less noise. Having a, permanently connected, very low Rs helps avoid much of any disadvantage of High Rin.
regards Andrew T.
Old 31st October 2010, 04:11 PM   #24
how can be corrected?
Old 31st October 2010, 04:42 PM   #25
why does it need to be corrected?
regards Andrew T.
Old 31st October 2010, 04:46 PM   #26
The input impedance of Borbely line amp it's very easy to tweak only changing 1 resistor per channel.
Old 31st October 2010, 04:48 PM   #27
Resistors valus for shunt stepped attenuator?Hide this!Advertise here!
Resistors for Stepped Attenuator stl Parts 43 2nd August 2016 05:04 PM
Calculation of stepped shunt attenuator Mick_F Chip Amps 2 25th January 2014 11:49 AM
Calculating a stepped attenuator resistors values... youyoung21147 Parts 3 13th June 2005 08:07 AM
Carbon film vs metal film resistors in a stepped attenuator? G Tubes / Valves 17 22nd August 2004 01:22 AM
Shunt volume controll (scaling the shunt resistors) Freddie Solid State 7 30th August 2001 10:47 PM
