ARC LS25 mkII noise level - Page 7 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 28th October 2010, 10:39 PM   #61
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
ok - then look for something which is in range of 10K:10K ;
preferably with one middle tap at least on one side , where you will connect that mid tap to gnd , and other two ends to + and - legs of balanced preamp output
the secondary - connect one leg to gnd , other to hot - on amp side
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 28th October 2010, 10:47 PM   #62
Got it! Thanks for your help. Looking forward to hooking it up soon.
Old 28th October 2010, 10:51 PM   #63
Zen Mod's Avatar
or even better - 10K:10K
where both windings have two sections , so thats in fact 2K5+2K5:2K5+2K5
connect it on preamp side with primary ends to hots and joined inner taps to gnd
then secondary with both 2K5 connected in parallel
that way you'll have 3db loss
Old 30th October 2010, 03:00 AM   #64
Been thinking about this a bit and why would I even need a center tap on the transformer? I can connect the shield on the balanced cable to preamp chassis ground and then tie the + and - to the transformer.
I am sure even the real good transformers are not exact between the 2 halves. So connecting the shield to center tap does not make sense to me. Can you explain?
ARC LS25 mkII tube change GeneJazz Analog Line Level 6 18th October 2010 04:09 PM
Squeaky Noise in ARC Dual 75 neddyboy Tubes / Valves 11 6th June 2007 04:58 PM
Noise level swaroopvg Chip Amps 0 11th July 2006 08:24 AM
Help! - Akai GX-95 MkII, Bias, Recording level zstoja Analogue Source 0 25th June 2006 07:49 AM
Copyright 1999-2017 diyAudio
