ARC LS25 mkII noise level - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 23rd October 2010, 08:15 AM   #11
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
looking at schematic - there is no need for pins 1 & 3 tying on LS25 side
anyway - I still think that active stage is redundant , having 1V sensitivity of power amp ;
regarding full compatibility-do not over-estimate their knowledge over their greed .
feed that amp from any source which have variable output and that will be music , comparing to LS25 usage in that situation .
then you can sell preamp and buy something "passive " with buffer
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 23rd October 2010, 04:08 PM   #12
Originally Posted by analog_sa View Post
Don't hold your breath. The tubes are only used as followers and their contribution to noise is minimal. I have once owned this unit and have no memories of excessive noise but maybe my noise requirements are not so demanding. Otoh, do not judge the sound of high quality tube preamps by the LS25 or any other ARC unit for that matter. Despite what a lot of audiophiles on agon say, they all suck sonically. No opinion about their power amps.
What in your opinion would be a great tube preamp? BAT? ARC has such a good reputation, I thought I'd give it a try. Of course, popularity hardly ever translates to quality so I am just beginning this tube audio journey.
The good thing about popularity is I can sell the LS25 for no loss in equity.
Old 23rd October 2010, 04:14 PM   #13
I will try your advice. I'll see if the music is better this way.
Old 23rd October 2010, 05:10 PM   #14
analog_sa's Avatar
That is also the reason i sometimes buy used commercial high end equipment -it tends to preserve value ahead of inflation. And i get to sulk at it
As for recommendation for other brands, not much help i'm afraid. All the commercial preamps i have owned have been really poor in some respect. For some reason i find it much easier to come to terms with factory made power amps rather than preamps.
It is always useful to keep a good passive attenuator around. These usually work well with tube power amps and even if they show some deficiencies of their own, in comparison to most active preamps they can really shine. My definition of a good pre is thus simple: the transparency of a Shallco attenuator switch but with much better bass and dynamics. Gain, as Zenmod says is entirely optional.
Old 23rd October 2010, 05:56 PM   #15
I see your standards are much higher than mine! I am actually quite happy with the sonic quality of the preamp. Just want to get the noise out. I don't think this is normal for this amp and there must be some reason electrically or otherwise.
It may just be some bad power filter caps in the preamp. The sound of this preamp is more to my liking than the Arcam solid state pre.
Old 23rd October 2010, 06:03 PM   #16
Zen Mod's Avatar
have you any source with adjustable output ?
CD player , for instance
Old 24th October 2010, 12:07 AM   #17
Yes, I do. I'll try it direct. The thing is the preamp is convenient in that I can plug all my different sources into it. Also, it has a recording loop as I do a lot of analog tape recording.
Old 24th October 2010, 12:12 AM   #18
Zen Mod's Avatar
Yes, I do. I'll try it direct. .........
I hope that meaning of "direct" isn't " without volume control "
...... The thing is the preamp is convenient in that I can plug all my different sources into it. Also, it has a recording loop as I do a lot of analog tape recording.
certainly ; but - I meant that you try that for test , then decide have you enough gain/grunt/music without active preamp
Old 24th October 2010, 01:56 AM   #19
of course. I'll use my source with an output control.
There is a company called Serious Stereo that makes passive preamps. I might try that if I have to send the LS25 for service. I think it is noisier than it should be. I'll talk with ARC this coming week about it.
Old 24th October 2010, 05:14 AM   #20
I checked it out with my Nakamichi Dragon as a source. It has more than enough volume. I think it sounds just as good with no noise from the preamp. However, I heard from a LS25 owner who states he has no noise from it standing in front of his speakers. So I'll have to get to the bottom of that.
There are some attractive passive preamps but none really have the input capabilities I would need. I need at least 6 inputs with the ability to monitor my recordings.
ARC LS25 mkII tube change GeneJazz Analog Line Level 6 18th October 2010 04:09 PM
Squeaky Noise in ARC Dual 75 neddyboy Tubes / Valves 11 6th June 2007 04:58 PM
Noise level swaroopvg Chip Amps 0 11th July 2006 08:24 AM
Help! - Akai GX-95 MkII, Bias, Recording level zstoja Analogue Source 0 25th June 2006 07:49 AM
Copyright 1999-2017 diyAudio
