Do all OPA2134PA's sound the same?
Old 10th November 2010, 10:42 PM   #11
Curmudgeon is offline Curmudgeon  United States
It's very likely that the OPA2134 has been "blessed" with several die shrinks for cost and yield improvement during its lifetime. When the analog IC houses were in their prime, and I was working for a major customer (Harris) I remember receiving notices of pending die shrinks, which detailed changes in non-data-sheet parameters, or shifts in typical values; min-max of course were almost never changed, and then only for the better.
Old 3rd July 2011, 08:11 AM   #12
karmik is offline karmik  Italy
karmik's Avatar
Send a message via ICQ to karmik Send a message via AIM to karmik Send a message via MSN to karmik Send a message via Yahoo to karmik
I came to this thread through a google search for "opa2134 counterfeit". I bought 5 2134s from ebay to build a Rod Elliott's P88 on breadboard (i fully intend to buy it as soon as i can afford it). I rebuilt the first stage twice already (no second stage yet, until i can fix the first), the last iteration seems to *work*, meaning it does amplify signal (140mv input, higher output), but the sound is AWFUL!
It sounds like a mistuned FM radio, completely distorted if i raise the volume even a little on the source and whenever there is a voice in the signal it's all "robotic". I'm gonna rebuild it a third time but i don't see how it can do its job if i mis-wired something but do it so badly.
The other components are
  • MKT caps rated for 100V (signal)
  • MKT caps rated for 63v (bypass on the opamp power pins).
  • 1% Resistors, from china as well (standard values for 3db gain)
Also, the opa2134s lack the "dent" between pin 1 and 8 that i saw on every other DIP package i've ever seen (not many, but still dozens of them).
I'm starting to think i ran into a counterfeit batch. This could very well be just a bad case of mis-wiring on my part (i'm very very very much of a newbie) but the weird distortion i'm getting is so fishy!
Anyone has info about this?
Old 3rd July 2011, 08:53 AM   #13
digits is offline digits
digits's Avatar
you sure you got the pots right?
Old 3rd July 2011, 08:57 AM   #14
karmik's Avatar
No pot wired by me, the volume i mentioned raising either is the one from the software mixer inside Windows 7 (outputting to either a USB Dac from Xitel based on PCM2704 or a Realtek integrated soundcard, i tried both) or of a pair of active pc speakers (outputting through the headphones out).
I Void Warranties
Old 3rd July 2011, 09:52 AM   #15
sofaspud is offline sofaspud  United States
sofaspud's Avatar
Your description sounds worse than what you'd get from a lowly 741 chip. Closely check your work; if it's not that than those OPA2134s aren't counterfeit... they are dud rejects!
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 3rd July 2011, 10:07 AM   #16
digits's Avatar
I've made a P88 before and it worked fine, nothing spectacular, but functional.
Old 3rd July 2011, 10:40 AM   #17
Mooly's Avatar
Originally Posted by karmik View Post
I bought 5 2134s from ebay to build a Rod Elliott's P88 on breadboard ...................
You mention a "breadboard layout" and that could (and without seeing its impossible to say) be the problem.
Maybe post a picture of your project
Old 3rd July 2011, 04:27 PM   #18
karmik's Avatar
I will rebuild it as i don't trust my skills. I have a Szekeres headphone amp made on breadboard a couple years back and it sounds quite fine so i don't think that's the problem
I want to say that i never said the project itself sounds bad. I'm willing to bet my pajamas that it will sound great once i get it right. I was complaining about my board, which is very likely badly soldered and/or has a counterfeit active element.
I will post a pic as soon as i make a third revision, i want to be extra-sure that i didn't get something wrong in this revision. Give me two or three days thanks for your help and sorry for hijacking the thread! :P
I Void Warranties
Do all OPA2134PA's sound the same?Hide this!Advertise here!
PC sound card sound chips kaluchka Chip Amps 6 20th June 2011 03:48 PM
The Ultimate Sound Improving for Compact Disc's through Patent-Pend.CD Sound Improver tiefbassuebertr Digital Source 145 25th April 2011 07:39 PM
comparing hi fi sound to car sound biamp Everything Else 12 27th June 2010 06:59 PM
SE sound vs Ultra Linear sound flysig Tubes / Valves 1 9th May 2009 10:21 PM
Eighteen Sound (18 Sound) NSD 1095N Compression Drivers and XT1086 Horns opc Swap Meet 6 1st May 2009 03:48 AM
Copyright ©1999-2017 diyAudio
