electronic crossovers which to buy
Old 26th September 2010, 08:30 PM   #1
pforeman is offline pforeman  United States
Default electronic crossovers which to buy
I am about to build another full range speaker system with powered bass units.
I'm planning on using my newly made simple se triode to run the full range unit, and my moscode amplifier for the bass unit.
I've looked at all the electronic crossovers I can find, and it seems like the features I want are all on the automobile electronic crossovers.
Unfortuneately, it must have rca jacks, and this eliminates almost all of the non auto crossovers.
I could build a simple power supply for it,
but
are car crossovers good?
Old 27th September 2010, 01:21 AM   #2
andyr is offline andyr  Australia
Try Rod Elliott's P09, here:
Linkwitz-Riley Electronic Crossover
That's what I use (except I don't use 24dB slopes).
Andy
Old 27th September 2010, 01:23 AM   #3
mac is offline mac  United States
mac's Avatar
Try here.
Old 8th May 2011, 11:55 PM   #4
noSmoking is offline noSmoking  United States
noSmoking's Avatar
I built this one very good and versatile,use sockets for the chips,then you can change them at will,the stock tlo74 aren't bad,no audible hiss,hum or pop,lol
Silicon Chip Online - Active 3-Way Crossover for Loud Speaker Systems
Old 10th May 2011, 12:34 AM   #5
Rush is offline Rush  United States
I don't see anywhere to buy the crossover. How much is it? Where do you pay for it?
Old 10th May 2011, 09:01 AM   #6
georgehifi is offline georgehifi  Australia
georgehifi's Avatar
Send a message via MSN to georgehifi
Here is a two-way version of it, and I used OPA4134, much better than the TLO74's.
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 10th May 2011, 02:03 PM   #7
noSmoking's Avatar
Default hi,
It has a article on it and the layout for the main board,and a BOM, I don't know if a kit is available for it ,
I built mine from scratch using that article,
Old 10th May 2011, 03:06 PM   #8
Tajzmaj is offline Tajzmaj  Slovenia
I vote for ,,mini dsp,,
Old 10th May 2011, 03:21 PM   #9
azneinstein is offline azneinstein  United States
pforeman- a gentleman that I had met, musician and DIY audiophile had done the same with a 12v p/s and auto crossovers. I thought it sounded good. So yes it's doable and it does work- but I'm also curious to see what the experts weigh in. Only "down" side I could think of is that Auto sources generally have a higher voltage in the RCA, not sure if that affects the distortion or SQ.
Old 10th May 2011, 11:05 PM   #10
From Pforeman's first post I assumed he was looking for a kit or pre-made crossover. I got excited from the link in your post that there was a kit with the metal work already done. Thats is the hard part for me.
Rush
electronic crossovers which to buyHide this!Advertise here!
where can I buy electronic parts? 52remi4ever Parts 7 19th March 2013 02:36 PM
Available EQ on combined electronic crossovers/ EQ: Berhinger, dbx, etc rick57 Digital Source 2 10th May 2011 02:09 PM
A couple of questions re: bi/tri amping, electronic crossovers EmergencyDpt Multi-Way 17 21st December 2008 09:18 PM
where can I buy electronic parts? 52remi4ever Vendor's Bazaar 0 19th February 2007 06:08 PM
