My Preamp Project: Arduino, I2C, relay selector+attenuator, tube stage
Old 9th September 2010, 02:58 PM   #1
maxw is offline maxw  United Kingdom
maxw's Avatar
Default My Preamp Project: Arduino, I2C, relay selector+attenuator, tube stage
I thought I would detail my preamp project. I've had this idea for a while but only recently got around to starting it. Seen a couple of threads previously with similar intentions but looks like they never got finishedÖ
Iím going to use an Arduino for control because I really like open source hardware and its so easy to work with. The Arduino will control a passive, relay-based input selector and Attenuator via I2C using a rotary encoder/buttons/remote. Not sure if Iíll use an LCD display in the final design but I have one at the moment anyway. Not sure about the tube stage yet but Iím thinking a Low Voltage Aikido (Aikido LV)
Attached is a diagram showing the general layout.
Old 9th September 2010, 03:54 PM   #2
Leon08 is offline Leon08  Germany
Banned
I think it's unnecessary complicated with tubes and relay-based Attenuator.You can take an Op-amp and pga2310 instead and it will cost less and make better sound.
I know some people want something extravagant and very expensive, but it sounds not better then "cheap" things.
Old 9th September 2010, 04:01 PM   #3
maxw's Avatar
Yeah I was very undecided about using the PGA2310 vs relay attenuator for volume control but decided on the relay attenuator purely because it was more interesting to build.
But I think quite a few people would disagree with you about a PGA2310 and opamp sounding better than tube stage and pot!
Old 9th September 2010, 08:04 PM   #4
Banned
I recomend this here RelaiXed -- Balanced pre-amplifier
if you want something special.
Old 9th September 2010, 11:00 PM   #5
maxw's Avatar
Yeah I've seen this design, its very good. My attenuator is pretty much the same schematic (also same as the Joshua Tree and Jos van Eijndhoven's work) except mine has double the amount of steps and its not balanced. I don't have any balanced equipment and I've never had any hum or interference so I don't really see the point of it. Mine also uses smaller relays and all SMD parts. I'll post schematics and layout soon!
Old 13th September 2010, 02:11 AM   #6
wabun is offline wabun  United States
I tried this, but it has bug, the rotary enoder need to debounce by 1uf capacitor
and the decrement has inconsistant result..
Old 14th September 2010, 01:33 PM   #7
maxw's Avatar
Here are some pics of the PCBs
Old 14th September 2010, 01:35 PM   #8
maxw's Avatar
Some of the features are:
I2C controlled using an MCP23008
The I2C address can be set using small DIP switches
Surface mount components for shortest possible signal path
PCBs are small (100 x 50 mm) and stackable
Should work as single ended or balanced (need to one per channel)
Omron G6K relays - High quality, low power, very compact with gold alloy contacts
The input selector has 5 inputs and 1 output relay for muting to stop preamp pop or thump etc.
The attenuator has 128 steps + mute.
Here is a pic of the bottom of the attenuator board
Old 14th September 2010, 01:36 PM   #9
maxw's Avatar
That's a shame!
I'm working on my arduino code now but so far it just seems so easy! I'll post results soon.
Old 15th September 2010, 11:06 AM   #10
qusp is offline qusp  Australia
qusp's Avatar
watching with interest. so has both attenuator and selector yes? or this is separate functionality from same board? will you have PCBs? I do not need tube stage, only balanced selector and attenuator, with buffer (I will just use IC or discrete diamond buffer)
My Preamp Project: Arduino, I2C, relay selector+attenuator, tube stageHide this!Advertise here!
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 16 18th May 2013 04:19 PM
Arduino based Input Selector for preamp _atari_ Analog Line Level 5 30th June 2010 03:42 PM
Relay Attenuator for tube amp Vidi Tubes / Valves 9 11th December 2006 05:09 PM
Relay - Selector Swich ruangrit Solid State 0 5th September 2003 05:58 AM
relay input selector macgyver Pass Labs 6 7th October 2002 08:33 AM
