Go Back   Home > Forums > Source & Line > Analog Line Level
Old 23rd December 2011, 09:02 AM   #51
maxw is offline maxw  United Kingdom
maxw's Avatar
Originally Posted by TheShaman View Post
Max,
What are the impedance specs of your attenuator?
I'm considering using it along with a Salas DCB1 buffer (which is optimally paired with a 10-20k pot).
It's the same schematic/specs as the AMB Delta:
The δ1 Relay-based R-2R Stereo Attenuator
I think my current one is around 20k.
Old 23rd December 2011, 10:26 PM   #52
glt is offline glt  United States
Originally Posted by maxw View Post
That is the example I was going to post as it neatly shows the problem with LCD screens - Yes they can look really nice BUT the front panel must be machined to fit the LCD perfectly. Having access to machining tools is a luxury I don't have. I think you need to know someone otherwise the tooling and set up costs are crazy! Cutting a nice circle using a hole saw with my drill press is about the extent of my tools
This is the kind of implementation that makes me dislike LCD screens:
DIY: AMB/linuxworks labs alpha10 audio preamp | Flickr - Photo Sharing!
Totally agree. But if you use wood and a steady hand you can get something like this:
Your implementation of a colored LED to indicate volume level is a great idea!
www.hifiduino.wordpress.com
Old 27th December 2011, 05:53 PM   #53
This is a pic (sorry for the poor quality and reflections) of the actual "user interface" of my preamp:
The preamp is still into the "prototype phase" (as you can clearly see ) but basic functions are already working.
"Selezione Ingressi" means for "Input Selection" and it is done by "clicking" with the finger on the correspondant icon.
Clicking on the volume level box activates the MUTE.
The volume is set by using a PGA2310 and an optic encoder, the balance function is made by regulating individually the volume of the desired channel.
Min and max value of the volume (shown in the "volume bar") are set in the configuration page (still in development) and the "volume bar" steps are calculated according to these values so that it reflects the actual volume level.
The volume level displayed in the box is calculated considering the total gain of the "analogic" preamp but this value will be "fine" adjusted when everything will be completed measuring the gain with an oscilloscope.
Old 27th December 2011, 09:41 PM   #54
I post the pic again since the previous seems to have a problem:
Old 28th December 2011, 09:36 AM   #55
maxw's Avatar
Very cool, love it. The cardboard and tape front looks good too
Did a library come with the touch screen? Or did you have to write your own?
Old 29th December 2011, 09:02 PM   #56
For a temp sensor project a little while back, I made this, using a hand drill, nibble and a file.
Bought the bezel from Digikey or Mouser, uses a standard 2x16 LCD, connected to an Arduino.
It also has a bluetooth interface, so I can get info through bluetooth to a Processing program running on a laptop. I have a switch to select USB or bluetooth on the arduino.
Randy
My system is here
http://randytsuch-audio.blogspot.com/2005/10/my-system.html
Old 29th December 2011, 09:59 PM   #57
Unfortunately not, I had to write everything by my own, included a font to display text messages but it's not complicated.
To manage the touch capability you need 4 ADC (analog to digital converter) to read a voltage that is proportional to the position of the screen where you touched.
It communicates with the micro through an 8 bit bus and has some control lines, the only command that you need is to send it the coordinates of the pixel that you want to turn on and the color of the pixel.
Actually to turn off a pixel you just need to send the color "0" (black).
The negative side of using color (graphic) LCD is that they need a lot of kbyte if you want to display a bitmap.
In my case to display a full 320x240 (256 colors) bitmap I would need 76800 bytes since every pixel is represented by its color that is codified with one byte or 8 bit (RRRGGGBB).
Old 30th December 2011, 12:26 AM   #58
Bonsai is offline Bonsai  Taiwan
Bonsai's Avatar
You can get a completely free high end graphics library from NXP that will run on any of it's ARM controllers. Go onto their website and look und MCU. The manual is 1000 pages long and is based on the Segga GL. The library includes full touch screen support.
bonsai
Amplifier Design and Construction for MUSIC! http://hifisonix.com/
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 16 18th May 2013 03:19 PM
Arduino based Input Selector for preamp _atari_ Analog Line Level 5 30th June 2010 02:42 PM
Relay Attenuator for tube amp Vidi Tubes / Valves 9 11th December 2006 04:09 PM
Relay - Selector Swich ruangrit Solid State 0 5th September 2003 04:58 AM
relay input selector macgyver Pass Labs 6 7th October 2002 07:33 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
