| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#11 |
Great ! I think this is the first time somebody does that in public. I always try to avoid common mode distortion in my designs but actually i measure and did not do listening tests other then checking the finished circuit.
#12 |
is the cancellation resistor a resistance in the normally seen shorting link of the opamp as (non-inverting) unity gain follower?
Normally we see Output connected to -IN as a direct short. This has come up in a couple of other threads recently. |
#13 | |
This was done by Silicon Chip magazine in their Studio Series Preamplifier of October 2005 with an OPA2134.(P.29) SandyK |
#14 |
Yes, this is a resistor between output and -IN.
#15 | |
#17 |
Yes. I know Groners work and of cause i know what Dougas Self has to say about it. Sofar i have only seen and done measurement and a listening test whould be really interesting.
#19 |
Silicon Chip mentioned in their article to use a resistor that's the same value as the wiper to ground resistance on the pot at your normal listening level. On my buffers I just tend to use 10% of the pot value.
No longer DIY active |
#20 |
To necrobump this a bit :
How is the distortion affected by signal level, i e CM voltage, fex if you have a volume pot before the buffer? Here and in Selfs book the testing is done at quite high voltage. I rarely feed 3Vrms into my power amps, as the distortion from the speakers probably outshine the buffer distortion by a couple of magnitudes then
listen! Can you hear that ... |
| Arjen's tube buffer for pre-amp | Josephjcole | Class D | 22 | 8th February 2010 01:18 PM |
| My pre-amp / buffer | SimontY | Solid State | 12 | 15th November 2008 05:48 PM |
| Pre-Amp / Buffer on Ebay | poynton | Solid State | 1 | 22nd June 2008 12:40 PM |
| Pre amp or Buffer for Inverted GC? | 5150ed | Chip Amps | 9 | 11th July 2006 06:27 PM |
| Building a pre-amp output isolation buffer? | rruss | Solid State | 4 | 18th October 2004 03:52 PM |
