what is an extended foil polystyrene?
How do you recognise it?
How bad is a polystyrene that is not extended foil?
I thought aluminium foil and polystyrene insulator were all that was needed for a good audio cap.
Do they make stacked film polystyrene?
All mine are clearly a long continuous coil.
What is an extended foil?These surplus Remix styroflex capacitors are not the extended foil types.
What tells them apart from a not extended foil?
Rifa say that the leads are soldered to the foil.
Does that mean the foil is lead and not aluminium?
See post 40.AndrewT said:What is an extended foil?
Unlikely to be lead. It is possible to solder to aluminium.Rifa say that the leads are soldered to the foil.
- Analog Line Level
- Polystyrene Caps For Filters
