Polystyrene Caps For Filters
Old 5th December 2010, 05:23 PM   #31
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Late production stage example of the Siemens KS series, and the final S+M version
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 5th December 2010, 05:38 PM   #32
Rod Coleman is offline Rod Coleman  United Kingdom
работник
Rod Coleman's Avatar
I tried the Russian 100n/250V K71 Polystyrols in RIAA. Shunt Cascode ECC189 architecture.
I did not like them - the bass really suffered, even after long running-in. I put back my ultra-high quality micas (made by TAB) and left them there.
I tried the ССГ micas too, in combination with K71. Still no good.
Old 5th December 2010, 08:34 PM   #33
wrenchone is offline wrenchone  United States
wrenchone's Avatar
Jaco, my Siemens caps are earlier production than that. I hadn't noticed them before at my local surplus place - maybe they were recent acquisitions for some newly defunct company or someone clearing their stockroom of obsolete material. Anyway, I grabbed a couple of bags. 1n2 is a good value to have for crossover frequencies ~5-6k. I might grab the rest when I go back.
Old 5th December 2010, 09:11 PM   #34
Who cares, i have them from late '70s to late '90s production.
Makes no difference to me, these parts virtually last forever, long term stability of polystyrene is top notch and i measure components just the same.
I've awaited superior low-value capacitors since the late '80s, there's been talk about poly-ethylene norbornene caps since the early '90s and still no go, at the current "Out-CD'd" price levels it's a waste not to grab some.
Old 5th December 2010, 09:13 PM   #35
imfree707 is offline imfree707  United States
imfree707's Avatar
Send a message via Yahoo to imfree707
Default Expensive, But Nice!
Defibrillator capacitors would be grand, if they were just affordable!
A stiff power supply in a great-sounding amp is always better for you than a stiff drink.
Old 5th December 2010, 09:21 PM   #36
wrenchone's Avatar
Jaco, I don't really care about the date either, it's just noted in passing. The caps I bought were in lots of 50 in their original poly bags - they must have been sitting in someone's stockroom for a while. I paid 30 cents apiece.
Having said that, I've noticed that some of the crummy laid-in lead type polystyrenes tend to craze a bit on the outside as they age, and that's not nice...
Old 5th December 2010, 09:45 PM   #37
Ah, i just remember i shack/shag with one of those >1/4m$ medical chicks
Old 11th December 2010, 08:15 PM   #38
FdW is offline FdW  Netherlands
FdW's Avatar
Siemens KS, I love them
http://www.diyaudio.com/forums/analo...aa-preamp.html
Frans.
Old 3rd May 2016, 10:57 PM   #39
Philipp23 is offline Philipp23  Germany
Hello
I know this thread is old but the question I will ask might be interesting for others. The question was asked before but sadly not answered.
What exactly are polystyrene extended foil capacitors? What is the difference between extended and normal foil polystyrene's? Would be really nice to get a detailed description of the construction of extended foil polystyrene capacitors.
Are they always superior to normal polystyrene capacitor or do they have also disadvantages? And finally how can we identify them? Are all box type polystyrene's extended foil polystyrene's?
Sorry for all those questions, but as mentioned before, the answers could also interesting for other members.
Kind Regards
Phil
Old 3rd May 2016, 11:13 PM   #40
rayma is offline rayma  United States
Extended foil types are wrapped with foil #1 extending out of one end, and foil #2 extending out of the other end.
Then each end is pressed together and connected to the leads by spraying, welding, or other methods.
Because all the turns of either foil are shorted together, the inductance is much reduced, since all the
turns are then in parallel instead of in series. This can be done with any type of film.
http://www.sbelectronics.com/wp-cont...strations1.pdf
Polystyrene Caps For FiltersHide this!Advertise here!
Silver Mica caps VS Polystyrene caps KevinLee Parts 41 11th November 2015 03:38 PM
xicon polystyrene caps? crippledchicken Parts 19 27th September 2012 10:12 PM
Styrol/Polystyrene Caps Bigred Parts 2 6th September 2010 08:49 PM
Polystyrene caps in a graphic equalizer stpa Solid State 3 10th April 2008 04:19 PM
Radial mount 1% polystyrene caps Drew.J.K Parts 1 21st June 2004 01:46 PM
