| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#871 |
diyAudio Chief Moderator
The answer is keep 10V Vin-Vout DC difference across the regulators if you can, given the right choices for your AC source.
#872 |
cheers Salas,
I was thinking along the same lines. If I use a 230v primary 15v secondary transformer with a 210v AC supply I should get approx 13.5v on the secondaries. with the same supply voltage the 18v spec version gives me 16.5v. If I could find a 17v transformer I think that I would have a perfect fit. The reason I asked in the first place was to see if the recommended specification at 15v had any flexibility ie. it was at it upper limits would work well with a slight voltage drop. Brad |
#873 |
Builder,
I recommend you look at three operational conditions. When mains is at nominal UK voltage of 240Vac. When mains is at 254Vac When mains is at 226Vac. Look at what happens to each component in the regulator for each of these three situations. It might also be worth looking at what happens if you have your DCB1 with it's mains transformer connected directly to 254Vac instead of using the balanced voltage dropper. Have you decided what CCS current you want to use? The AC current rating of each winding must be at least twice the DC current you plan to draw and preferably four times your CCS currents. |
#874 |
What order is best for the following matching 2SK170-BL’s,
7.15/7.14 - 7.15/21 (1,2,3,4) or 7.15/7.15 - 7.14/7.21 (1,2,3,4) |
#875 |
714/721 will give a higher (-ve) output offset. That's a 1% difference.
#876 |
Thank you Andrew.
#877 |
Instead of the BOM specified 15-0-15V 50VA transformer recommended for the 200mA hotrod, is it possible to use a 12-0-12 V 48VA (or alternately 72VA) version instead? (reason is my local store carries only 12V versions, next step up are 18V variants).
For those who have tried both - are there any sonic benefits to using the 15V traffo over a 12V one? Thank you for all the replies. |
#878 |
Will work with 12-0-12VAC OK. Does your local power company vary the mains significantly? Not to go much lower.
#879 |
#880 |
Add two windings giving an extra 2 to 3Vac to add on to the 12Vac.
| dcb1 buffer with shunt reg. | merlin2069er | Swap Meet | 0 | 3rd August 2010 05:25 PM |
| F2 and DCB1 parts selection - please advice! | DQ | Pass Labs | 6 | 25th November 2009 03:20 PM |
| Y B Blue - how blue LED improves the CD playback | Peter Daniel | Digital Source | 176 | 25th September 2003 07:40 AM |
