Salas hotrodded blue DCB1 build
Old 12th March 2011, 02:49 PM   #791
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by 10y View Post
Hi Salas!
thanks for your reply.
Yes I will substitute the sinks with more efficient models.
My audio chain tourns around altec 414 onken bass with medium 288 16g/ 311-60 altec horn system and gauss 1505 tweeter.
Pre diy: ugs all inclusive, l'euridice (tube pre with ec8010 and output tx).
Ampli diy : aleph 30 ( hotroddedd at 1,10 A per mosfet)
up
il triodino (single ended 6c5 fivre with electro harmonix 300b)
Dac : assembled around four 1704 burr brown and ecc 188 tube I/V
conversion
I'm very happy with it.
Ciao,
Anto
Interesting system. And what are you planning to do with DCB1? Use it alternatively to a preamp, or just buffer a DAC? You should watch grounds with so sensitive loudspeakers for no buzz. Let us know impressions. Regards.
Old 12th March 2011, 02:53 PM   #792
To buffer the Lightspeed in the earlier post.
regards Andrew T.
Old 12th March 2011, 03:15 PM   #793
Salas's Avatar
The future LSPD yes, but still as a general pre or for the DAC only?
Old 12th March 2011, 03:44 PM   #794
10y is offline 10y  Italy
I have built pass f5, penasa my ref and my evo too...
For now I will use dcb1 with lightspeed as general pre swapping it with the others pre.
Very interesting idea buffer dac with it.
Could be put into a greater case with one of penasa's ampli in order to obtain an integrated amplifier for a second smaller hifi chain.
Will post some listening impression soon....
Ciao,
Anto
Old 12th March 2011, 07:27 PM   #795
Salas's Avatar
I see many pairings with DCB1 & F5 but I wonder if the total gain is enough in all those cases. Takes about 3V RMS capable source. Its much easier with horn speakers on the other hand.
Old 13th March 2011, 09:53 AM   #796
I will tell about this combination;
anyway my dac can output that signal level
Anto
Old 15th March 2011, 07:10 PM   #797
crazyfrog is offline crazyfrog  Canada
Default Vishay 234R
I have on hand few Vishay 234R. Can I use them instead of 220R?
Old 15th March 2011, 07:37 PM   #798
Atilla is offline Atilla  Norway
Yeah, that's a fairly small difference, it shouldn't be a problem.
Old 16th March 2011, 01:19 AM   #799
johnwmclean is offline johnwmclean  Australia
Hello Salas, Iím trying to find out as much as I can regarding balancing a blue DCB1 build (using 2 boards). I have not come across any completed builds that have are balanced as yet, information is sparse, I have spend considerable time searching in vain. Iíve posted this layout in the Mesmerize build thread, AndrewT responded kindly regarding the importance of matched impedances for the input and output, thanks Andrew.
Is there anything else that would be of importance with such an undertaking would any component changes benefit from balanced operation? Is this layout workable?
Thanks for a wonderful project.
John
Old 16th March 2011, 02:11 AM   #800
Salas's Avatar
Hello. Since I don't have balanced DIY gear, I never attempted a balanced DCB1. Thus I can't give you any expert advice. I can only comment that whatever applies for balanced wiring in a regular B1 applies to DCB1 equally. There were a couple of connection schematics proposed in B1 & DCB1 threads, not some finished application shown yet. Yours looks logical for connectivity too. Why the Zobel? To track Zo better supersonically between phases?
Salas hotrodded blue DCB1 buildHide this!Advertise here!
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 06:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 04:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 08:40 AM
