Salas hotrodded blue DCB1 build
Old 18th August 2010, 08:22 AM   #71
Marra is offline Marra  United Kingdom
To ground the circuit I need to connect from the centre connector on the p/s input to chassis earth through a cl60?
Old 18th August 2010, 12:40 PM   #72
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
That's right, Marra.
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 18th August 2010, 01:43 PM   #73
Thank you.
Old 19th August 2010, 07:45 PM   #74
I seem to have run out of 47R resistors would there be a problem in using 49R9 instead?
Old 19th August 2010, 09:18 PM   #75
regiregi22's Avatar
It should work, but Salas can confirm that.
Old 20th August 2010, 07:36 AM   #76
I've decided to give Shinkoh tantalums a try in the buffer stage so I've ordered some 47R resistors as well
Old 20th August 2010, 02:47 PM   #77
dvb projekt is offline dvb projekt  Germany
dvb projekt's Avatar
Ive got my SK170 from Blues today. One pair with 8.79 & 8.80mA and one pair with 8.76 & 8.77mA.
With the latter in the inner position, i have two possibilities:
  1. 8.80 - 8.77 / 8.76 - 8.79
  2. 8.80 - 8.76 / 8.77 - 8.79
Witch one should i solder?
Reference TDA1541A DAC project PCBs / Tube-I-zator PCB
Stock status in my Blog
Old 20th August 2010, 02:50 PM   #78
regiregi22's Avatar
I would bet none of them. I would place each pair paired as you got them. But that's my POV.
Old 20th August 2010, 02:51 PM   #79
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
8.80-8.79-8.76-8.77
Old 20th August 2010, 03:13 PM   #80
Originally Posted by Salas View Post
8.80-8.79-8.76-8.77
Thanks Salas.
Salas hotrodded blue DCB1 buildHide this!Advertise here!
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 05:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 03:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
