Salas hotrodded blue DCB1 build
Old 22nd December 2010, 07:04 AM   #711
Rodeodave is offline Rodeodave  Austria
hates ground loops
Rodeodave's Avatar
I wouldn't say "necessary", just very very beneficial. Especially if the heatsink's contact surface isn't the smoothest. The idea is that you increase the contact area between two solid surfaces that are not perfectly flat. You only need very little, I usually apply it to the semiconductor and spread it with a toothpick, and once you tighten the mounting screw you can remove the excess goop. Locally you might find some in a computer store (for CPUs).
Gravity - Making the G since 13.7 billion B.C.
Old 22nd December 2010, 07:58 AM   #712
Marra is offline Marra  United Kingdom
The reply from "Along"
Hello,sir
Due to the bad weather recently,The air mail are very very slow,most of our package sent to UK on early November still on the way,many buyers impatient to wait so long delivery time and open disputes to ask full refund,so,we only can except some countrys temporary.
We appreciate your understanding.
Best regards
Merry Christmas!
Old 27th December 2010, 04:12 PM   #713
merlin2069er is offline merlin2069er  Canada
merlin2069er's Avatar
Send a message via MSN to merlin2069er
I've got them powered up.
I forget what I should test for voltage wise. Anyone have references voltages I should look for?
Folding the mosfets over was the only way I was going to mount these heat sinks. I'm wondering if I should drill another hole in these mosfets and secure them to the chassis.
Merry Christmas,
JG
Old 27th December 2010, 04:17 PM   #714
Atilla is offline Atilla  Norway
+/- 9-10-11ish volts is what you're looking for as output.
Old 27th December 2010, 04:44 PM   #715
hates ground loops
Rodeodave's Avatar
Drilling another hole in the Mosfets? You're joking, right? Don't do it.
Are the Mosfets electrically insulated from the heatsinks? Otherwise your setup is prone to shorts.
Look for my build a couple of posts back and you'll find some reference voltages. Easy and probably first thing to check is the buffer's output offset relative to ground, which should be smaller than 5mV in either direction.
Nice build!
Old 27th December 2010, 09:33 PM   #716
No, I just have some thermal grease between the mosfets and heat sinks.
I've had to drill a hole in each of them so I could actually fit them onto the board.
Old 27th December 2010, 11:59 PM   #717
Ok, I guess I'll have to pick up some of these?
AAVID THERMALLOY | 189790F00000 | TO-218/TO-247 Package 0.009" Thick No Adhesive Silicone Insulator - Future Electronics
Old 28th December 2010, 12:19 AM   #718
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
You will do well to pick some of those for using in power amps output stages also. Very handy. You meant you drilled holes lower on the sinks I suppose on your previous posts? Not on the TO-247s themselves, yes?
Old 28th December 2010, 01:12 AM   #719
Yes, I drilled holes lower on the heat sinks so I was able to mount the mosfets on the board.
I have thermal grease, not insulators between them. I was thinking of securing the heat sinks to the chassis.
Old 28th December 2010, 01:23 AM   #720
Salas's Avatar
Only after insulation you secure them to the chassis. Else you will zap them.
Salas hotrodded blue DCB1 buildHide this!Advertise here!
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 05:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 03:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
