Salas hotrodded blue DCB1 build
Old 9th December 2010, 07:34 AM   #691
bkdog is offline bkdog
Default Multiple buffers from one supply?
I'd like to build a DC buffer for a balanced system, ins and outs, so that's 8 channels. Would anyone who has built and tested this PCB know if I would need to build all of the power supplies, or could I run, say, all of the input buffers from one supply board and the same for the outputs? How detrimental would it be to run all of the buffers from one pair of supplies?
Many thanks,
BK
Old 9th December 2010, 07:09 PM   #692
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Haven't built such configurations, can't tell at what point they can be compromised subjectively on what number of common PSUs if at all.
Old 20th December 2010, 03:35 PM   #693
RichLund is offline RichLund  United Kingdom
OK here it is at last, my all in one pre - DAC with Buffalo 24/Legato, DCB1 and Optical Volume control.
It works very well indeed, great sound. Please excuse the frightful wiring I fully intend to tidy it all up. This is just a lash up to see if all works.
It is interesting that comparison with and without the DCB1 is that the buffer pre adds substantial bass and somehow fills the sound out.
I have one slight problem, nothing major but it bugs me. The IRFP140 nearest the power supply runs a lot hotter than the other devices. It is within the 5 second touch test but the others are a lot cooler. What would this be? I guess i need to get a new batch and do a better selection of the LED's? The LED's selected were around the 1.63V mark tested using the diode test on my multimeter.
Voltage rails on the DCB1 are -9.14 / +9.15. Using 10R current setting resistors.
Is there an easy solution for the odd heat issue?
Anyway, I'm very happy and the whole thing is a great combination. Good work Salas!
Rich
Old 20th December 2010, 03:44 PM   #694
Salas's Avatar
Looks very nice, congratulations for your build. You mean one of the DCB1's 140 runs hotter or one in another supply? If it is a CCS 140, check the running current derived by the voltage on its setting resistor divided by the resistor's value. Not very big sinks and more enough mA due to maybe healthier leds, and/or weaker Vgs can combine.
P.S. If the above does not apply when you check, look also if the external filter board and wiring can be putting a CCS 140 into oscillation. Try a 0.1uF across V+ to GND where the wires land on the Blue if local steady state current does not explain the thermal difference.
Old 20th December 2010, 04:10 PM   #695
Thanks Salas.
Yes I meant the DCB1 140 is hotter. I just checked and the Voltage across the 140 setting resistor is 2.014V (so around 200mA?) the other rail is 1.544V. So It looks like the positive rail (IRFP9140) is low?
I hadn't thought that the filter supply board may be causing the problem. I should possibly eliminate it by trying the recommended 4700uF caps on the blue pcb.
Should I get LED's with a forward voltage of 1.8V - 1.9V?
cheers
Rich
Old 20th December 2010, 04:16 PM   #696
Originally Posted by RichLund View Post
Voltage across the 140 setting resistor is 2.014V (so around 200mA?) the other rail is 1.544V..................
no, just change the resistor to bring the CCS current to match the other CCS.
regards Andrew T.
Old 20th December 2010, 04:22 PM   #697
Salas's Avatar
Thanks Salas.
cheers
Looks straight forward, its explainable by the current difference, not by oscillation. Do as Andrew said. Find balanced enough currents by trimming the setting resistors, and a comfortable to your sinks ballpark.
Old 20th December 2010, 04:32 PM   #698
Nice one Andrew, should have thought of that. Obvious answer really! I'll probably have to wait until after the holidays to get some new resistors.
I shall bring the low current rail up to meet the other 200mA rail. Thanks guys, I now realise that the one I thought was too hot is fine, it's the other side that is too cool!
I'm a bit tired here and have a mental block - what value resistor should I aim for to balance the ccs?
Out of interest what would cause this imbalance?
Thanks again chaps
Rich
Old 20th December 2010, 04:57 PM   #699
Salas's Avatar
Different enough Vgs mainly and maybe happier leds contributing is the cause. Pretty natural, Mosfets vary for Vgs, you can easily hit upon a marked difference. I would target 180mA since with 200mA your sink gets a bit loaded. That would mean 2X22R 2W in parallel for the circa 2V side and 2X17R 2W in parallel for your 1.544V side.
Old 20th December 2010, 05:21 PM   #700
Marra is offline Marra  United Kingdom
Nice work Rich.
From where did you obtain the R cores?
Marra
Salas hotrodded blue DCB1 buildHide this!Advertise here!
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 06:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 04:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 08:40 AM
