Salas hotrodded blue DCB1 build
Old 11th November 2010, 05:22 PM   #611
knassiri is offline knassiri  United States
Salas,
This is my first build so please bear with me. I'm a little confused with what I'm seeing printed on the board relative to the BOM. I see mur820 on the board but no mention of these rectifiers in the BOM. Is this the location on the board where I use the recommended mur840's for the 'stage 1' build?
Old 11th November 2010, 05:46 PM   #612
Rodeodave is offline Rodeodave  Austria
hates ground loops
Rodeodave's Avatar
Yes, there (at the edge of the board) is where the bigger TO-220 style diodes go. The BOM lists MUR840 or MUR860, which are higher voltage versions of the MUR820.
Gravity - Making the G since 13.7 billion B.C.
Old 11th November 2010, 05:56 PM   #613
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
and importantly, higher current.
Salas Boards 2018#1 On Order | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards, PS and transformers Available PM | Sony VFET CSX2 AL boards In Stock
Old 11th November 2010, 06:18 PM   #614
Thanks guys.
Old 11th November 2010, 06:25 PM   #615
hates ground loops
Rodeodave's Avatar
I think the 8 in MUR820 is for 8A and the 20 is for 200V. 40 is 400V and 60 is 600V.
The datasheet suggests that they benefit from a heatsink, but I doubt that it's an issue at currents needed for the DCB1...
http://www.datasheetcatalog.org/data...8ed5gzfe3y.pdf
Old 12th November 2010, 02:31 PM   #616
Sorry for the rudimentary questions. Is the higher voltage of the MUR860's going to be an issue if I'm hotrodding to 200mA? These were the only values I could find that weren't back ordered.
Old 12th November 2010, 02:36 PM   #617
Tea-Bag's Avatar
It will be fine. They are just nice diodes. Lot of stuff uses them with low current.
Old 12th November 2010, 07:25 PM   #618
Great, thank you Tea-Bag. I went ahead and splurged for the naked Vishay's you referred to earlier in the thread. I ordered directly from Texas Components and was quoted a two week lead time. Curious to hear how the tx2575's compare to the Takman's that are in the board.
Old 15th November 2010, 05:08 AM   #619
rothay is offline rothay  United States
I'm looking to hot-rodded the mesmerize board to 600mA with MUR820. I'm looking to mount MUR820 off-board a thick aluminum plate beneath the board. Would there be any noise or performance issue running wires between the diodes and board?
Old 16th November 2010, 05:53 PM   #620
merlin2069er is offline merlin2069er  Canada
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Hey,
I got my caps mkp-1837, so I mount these in these in the 100uf position on the top and bottom.
Just double checking...
Thanks,
JG
Salas hotrodded blue DCB1 buildHide this!Advertise here!
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 05:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 03:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
