Salas hotrodded blue DCB1 build - Page 61 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 6th November 2010, 11:24 PM   #601
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Originally Posted by AndrewT View Post
do you mean that the CCS sets the current draw for the regulator circuit, or do you mean how to set the CCS current draw?
hmm, what I mean, is how is the 300ma current set.
Old 7th November 2010, 09:18 AM   #602
look at a standard two BJT transistor CCS.
The resistor in the supply route has a Vbe across it from the control transistor.
The pass transistor is controlled by that second transistor.
A BJT has nearly constant Vbe over a wide range of Ic. This allows the resistor that is parallel to Vbe to see a nearly constant voltage and thus pass a nearly constant current.
The resistor sees a voltage and passes a current based on Vbe / R, eg. 620mV/ 220r ~ 2.8mA
The FET type CCS works the same way.
The resistor sees a nearly constant voltage and the FET passes that constant current to the load.
In the SALAS style, the voltage across the resistor is not from a second transistor.
The resistor voltage comes from the Vgs of the FET and the Vf of the LED string. Vgs of a FET is substantially constant over a wide range of Id.
Current is defined by [Vfleds-Vgs] / R, eg [(1.8*3)Vfleds-4.1Vgs] / 33ohms = 1.3/33 ~ 0.039A = 39mA
The supply transformer+rectifier+smoothing caps sees a near constant load of ~39mA + [the current through the LED string that runs initially parallel to the setting resistor and then to Ground].
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 8th November 2010, 12:59 PM   #603
Nearly finished my DCB1, just waiting for a few bits.
Salas - is it ok to use 2R resistors in place of the 2 x 1R?
Cheers
Rich
Old 8th November 2010, 02:45 PM   #604
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Yes, its OK.
Old 9th November 2010, 03:48 PM   #605
Are these the right size for the PS section?
4700uf / 63VDC, MLytic® Audio Grade Snap-In, 30mm x 40mm
I'm going to order a few...
Old 9th November 2010, 03:54 PM   #606
They are still too big. The caps need to be 25mm max diameter. You need the 40V version of those caps, if you can find them.
Unless you are absolutely commited to having Mundorf caps, Can I recommend the 4700uF / 63V, Nichicon KG Series, Gold Tune, 25x50 from PX:
https://www.partsconnexion.com/capac...chicon_kg.html
Or Panasonic TSUP are excellent PS caps.
Rich
Old 9th November 2010, 04:03 PM   #607
Nick77 is offline Nick77  United States
Isnt this Mundorf cap at partsconnextion a good fit?
https://www.partsconnexion.com/capac...rf_snapin.html
MUNDORF-71841
4700uf / 40VDC, MLytic® Audio Grade Snap-In, 22mm x 30mm, 68 ESR (mOhm) 10 ESL(nH)
Old 9th November 2010, 07:01 PM   #608
I bought antek's 0512 transformers for my older (not blue edition) dcb1 buffer. I was going to use them for my blue edition, but I don't think they can power the blue edition buffers.
Old 9th November 2010, 07:09 PM   #609
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
depends on what kind of current your going for.
Salas Boards GB 2017#1 ON ORDER | GB 2017 #2 Click Here to Sign Up! | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards On ORDER
Old 11th November 2010, 02:38 PM   #610
Ed LaFontaine's Avatar
Location: where the Appalachians rise from the Blue Grass
Default Omron G6H-2 12VDC relays
Greets,
In support of stuffing these boards I have started an interest thread in the Swap Meet to supply the Omron G6H-2 relays. Express your interest there.
It appears there is sufficient stock currently available. However they are no longer being produced.
Thanks for all
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 05:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 03:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
Copyright ©1999-2017 diyAudio
