Salas hotrodded blue DCB1 build
Old 14th August 2010, 09:10 AM   #51
dvb projekt is offline dvb projekt  Germany
dvb projekt's Avatar
Originally Posted by RichLund View Post
I had also considered this and will be re-installing the input cap on my NCC poweramp. Something like a 3.3 - 10uF polyprop would do.
I recommend the K4700 speaker protection kit from Velleman. Very effective and no loss to sound quality as far as I can tell:
ESR Electronic Components - Velleman Kits
Decent kits are also avilable from SKA Audio and ebay -
SKA sponsored Audio Forum - Products
Stereo Speaker protection kit components DIY NEW A16 on eBay (end time 26-Aug-10 10:15:24 BST)
Speaker protection circuit dual mono 30A BTL /stereo ! on eBay (end time 03-Sep-10 15:07:48 BST)
To make the protection kit recommendations complete:
Aussie Ampīs LSP-1
Oliver
Reference TDA1541A DAC project PCBīs / Tube-I-zator PCB
Stock status in my Blog
Old 14th August 2010, 10:31 AM   #52
LucasAdamson is offline LucasAdamson  United Kingdom
LucasAdamson's Avatar
Aussie Ampīs LSP-1
Oliver
These are all pretty much if not completely sonically transparent, so I wonder what the point of buying such an expensive kit is??
Lucas
Old 15th August 2010, 06:07 PM   #53
ppcblaster is offline ppcblaster  United States
Default Irfp240
Looking at the Blue Board their is no indication as to where the N-Channel and P-Channel are placed.
The only indication of polarity is the V+ and V- printed on the board next to 3 holes marked "G" and 10 20 30 and J2.
Is this the indication to place the N_Channel mosfets on the V- and the P_Channel on the V+ side of the Blue Board?
Old 15th August 2010, 06:28 PM   #54
It gives the numbers IRFP 9240 for P channel and IRFP240 for the N channel (note the number 9 in the middle of the P channel number!)
Also, yes, the P channel is on the + side of the reg.
Lucas
Old 16th August 2010, 01:17 PM   #55
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
Originally Posted by AndrewT View Post
I recommend a 200r output resistor to all 4 RCA outputs.
i.e. don't share the existing 200r between a DC and an AC output.
May I ask why if they are not going to be connected simultaneously? The other end of the cap would hang off disconnected
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 16th August 2010, 01:41 PM   #56
R.I.P.
I would not leave the other end disconnected. I would use a 1M0 or 2M2 to DC reference the Hot to audio ground.
If I have two outputs, one AC coupled and one DC coupled, I would be very tempted to try a bass or sub-bass amp/speaker on the DC coupled output and reserve the AC coupled output for Mid and/or Treble amp/speaker. That way I can put in a low value, high quality, coupling/DC blocking cap that is affordable.
regards Andrew T.
Old 16th August 2010, 04:36 PM   #57
When is J1 used on the Blue Board?
J2 is used with 12V relay, correct?
Where is the Build Manual?
Old 16th August 2010, 04:58 PM   #58
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
J1 is used always. J2 is used always. The ''NOTE'' resistor is replaced with a jumper when having a 12V relay as it is explained under ''NOTE:Replace...'' on the board itself. If with 5V relay its 2 600R resistors side by side.
There is no build ''manual'' that I am aware of.
Old 16th August 2010, 05:24 PM   #59
Thank you,
I need to install a jumper wire on J1 because one is always needed and
I am using a 12v relay I need to install a jumper wire on J2
and not install the 2x 600R's?
Old 16th August 2010, 05:30 PM   #60
Salas's Avatar
And use a jumper instead of any 600R where it says note.
Salas hotrodded blue DCB1 buildHide this!Advertise here!
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 05:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 03:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
