Salas hotrodded blue DCB1 build
Old 26th October 2010, 10:55 AM   #561
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
The Vishay come up on ebay in very small numbers from time to time in no full values order. For about $5 each. At 0.1% tolerance.
Old 26th October 2010, 12:22 PM   #562
R.I.P.
Originally Posted by Nikon1975 View Post
Could this fit as pot choice ?
Hi-End Volume Control DIY Kit,LED, Remote Control /V-03 - eBay (item 290485343961 end time Nov-07-10 04:10:12 PST)
It says max out impedance 22K.
Thanks,
Davide
the ad, says "impedance varies".
It also says "super stable output impedance".
I think the impedance you quoted is the variable input impedance to achieve a near constant output impedance.
but I could be wrong.
regards Andrew T.
Old 26th October 2010, 12:42 PM   #563
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Originally Posted by LucasAdamson View Post
I am using PRP Audio grade Metal Film resistors, which cost 30c each. The price/quality ratio for these is unsurpassed, period.
I think it's pretty ridiculous to spend that kind of money on resistors before you've let the circuit settle in - like using $30 silver/gold film caps in a power supply or gold wiring.
For me, such resistors would be a potential tweak for a year or so down the road, if I felt the need. That way you can hear for yourself if you've wasted you're money or not.
I agree with your comments re PRP. However, after listening to Kiwame, PRP, Takman Rex, Caddock MK132 and TX2575, I vote for these in this circuit.
Old 26th October 2010, 01:25 PM   #564
samoloko is offline samoloko  Bulgaria
and what Is your second choice
has anyone think of new project - quality relay volume control for this
something like shunt pot
Old 26th October 2010, 02:34 PM   #565
Nikon1975 is offline Nikon1975  Austria
That's what I am trying to achieve.
Old 26th October 2010, 04:06 PM   #566
well at least we (Tea Bag) got the most expensive part - relays
my basic Idea Is to switch shunt pair of resistors conected to 2 NO contacts of one tq2 relay
rotary switch will power only one shunt pair at the time
the only problem Is that for each step will need two tq2 relays - unbalanced and four when go balanced
Old 26th October 2010, 11:01 PM   #567
This is the question I was asking before. From what I understand the configuration you propose is good if you need to keep the impedance constant. But if you have the buffer you do not really need, and you can have a shunt configuration, that let you use half of the relays. Am I correct ? Mostly if you use two buffers, one before and one after. The source and the amp will never know what is in the middle.
D.
Old 27th October 2010, 12:54 AM   #568
merlin2069er is offline merlin2069er  Canada
merlin2069er's Avatar
Send a message via MSN to merlin2069er
you mean something like this?
Joshua Tree - A Twisted Log Attenuator
Old 27th October 2010, 06:36 AM   #569
this Is what am talking The relay-switched attenuator volume control
It Is shunt type - the signal pass at only 2 resistors at the time and relay contacts
and gives constant Impedance
all other volume controls I have seen pass signal through many resistors / relays and are not of Interest to me
the only problem here are count of relays - but In practice we only listen to not more than 16 step of attenuation
Old 27th October 2010, 10:59 AM   #570
R.I.P.
impossible.
Either the input impedance will vary with attenuation required or the output impedance will vary with attenuation required.
You cannot get both input and output impedances unvarying with switched twin resistors.
regards Andrew T.
Salas hotrodded blue DCB1 buildHide this!Advertise here!
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 05:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 03:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
