Salas hotrodded blue DCB1 build
Old 10th August 2014, 08:17 AM   #4241
R.I.P.
turning the volume control above 9:00 or 10:00 was getting uncomfortably loud;
this tells you and us nothing.
We don't know what attenuation is being applied.
We don't know where in the clock max is, nor where min is.
fully cw was 6:00 and fully ccw was about 7:30. So 12:00 was 12 steps down from full volume, and was actually less than half rotation.
this tells us where min and max are, but not the attenuation at your preferred setting.
I usually have my DCB1 volume knob at or slightly above 12:00
your earlier post tells us nothing.
regards Andrew T.
Old 10th August 2014, 07:49 PM   #4242
nezbleu is offline nezbleu  Canada
nezbleu's Avatar
We don't know where in the clock max is, nor where min is.this tells us where min and max are, but not the attenuation at your preferred setting.your earlier post tells us nothing.
Gee, I thought I told you exactly what I wanted to tell you. I told you that in both cases I was using a "standard" log taper pot. I know that there are many "log tapers", but they tend to share some characteristics. Take a look at this PDF from Bourns, for example: http://www.bourns.com/pdfs/gapno_pan...rols_taper.pdf Most audio-taper pots are similar (Alps have a very similar document), and have about 90% voltage attenuation at 50% rotation.
Further, I told you that with the DCB1 I am able to use a larger part of the available rotation of the volume control, and I like that.
Since you seem top want some more details, I measured the resistance of both pots. I measured them in-circuit, but of course with power off. The readings will be slightly off because of other elements in the circuit, but still should give you a good idea. The Arcam Delta 290 integrated amplifier uses a motorized 10K "A" taper pot. There are "index" marks around the volume knob, so I measured at each of those marks, although there are no detents. The DCB1 uses a 20K 21-step attenuator. I measured one channel in each case. Here are the results (R is resistance from input to wiper in kilohms, the rest should be self-explanatory):
Code:
Arcam
		R	V ratio	% att	dB
ccw		9.9	0	100.0%	-inf
		9.87	0.003	99.7%	-50.37
		9.79	0.011	98.9%	-39.08
		9.72	0.018	98.2%	-34.81
		9.61	0.029	97.1%	-30.66
		9.53	0.037	96.3%	-28.55
		9.35	0.056	94.4%	-25.11
		9.07	0.084	91.6%	-21.53
		8.76	0.115	88.5%	-18.77
50% rot	        8.4	0.152	84.8%	-16.39
		8.11	0.181	81.9%	-14.86
		7.75	0.217	78.3%	-13.26
		7.34	0.259	74.1%	-11.75
		6.37	0.357	64.3%	-8.96
		5.24	0.471	52.9%	-6.54
		4.13	0.583	41.7%	-4.69
		2.68	0.729	27.1%	-2.74
		0.54	0.945	5.5%	-0.49
cw		0.05	0.995	0.5%	-0.04
Code:
DCB1
ccw		19.63	0.000	100.0%	-inf
		19.61	0.001	99.9%	-59.84
		19.57	0.003	99.7%	-50.30
		19.50	0.007	99.3%	-43.58
		19.40	0.012	98.8%	-38.62
		19.27	0.018	98.2%	-34.73
		19.12	0.026	97.4%	-31.71
		18.91	0.037	96.3%	-28.71
		18.64	0.050	95.0%	-25.95
		18.32	0.067	93.3%	-23.51
50% rot  	17.91	0.088	91.2%	-21.15
		17.40	0.114	88.6%	-18.89
		16.74	0.147	85.3%	-16.64
		15.92	0.189	81.1%	-14.47
		14.92	0.240	76.0%	-12.40
		13.62	0.306	69.4%	-10.28
		12.00	0.389	61.1%	-8.21
		10.00	0.491	50.9%	-6.19
		7.38	0.624	37.6%	-4.10
		4.13	0.790	21.0%	-2.05
cw		0.00	1.000	0.0%	0.00
Do you feel any better informed?
Old 11th August 2014, 08:30 AM   #4243
R.I.P.
Are you confirming that you listen @ -16dB
regards Andrew T.
Old 11th August 2014, 04:14 PM   #4244
nezbleu's Avatar
Depends on who else is in the room, but yes, that would be the "loud" end of the range where I listen.
Old 12th August 2014, 08:19 AM   #4245
R.I.P.
I use self-powered Linkwitz Pluto speakers, and I usually have my DCB1 volume knob at or slightly above 12:00 (or let's say between 10:00 and 2:00). I consider this a good match.
regards Andrew T.
Old 12th August 2014, 05:05 PM   #4246
nezbleu's Avatar
Yes, so now since we know I used the Arcam with the volume control in the 8:00-11:00 range, it is left as an exercise for the reader to determine the voltage gain of the Arcam preamp stage
Old 13th August 2014, 08:57 AM   #4247
R.I.P.
It does not matter. What does matter is the overall gain of the amplifier.
In the other case your amp would have a gain, let's assume it is +28dB
and assume you have an RF filter fitted as well that loses another 1dB.
The preferred vol pot setting you listen at is -16dB.
The gain from the Source to the Speakers is (+28 -1 -16) = +11dB
i.e. the Speaker voltage is ~3.6 times the Source voltage.
You can measure this with a test signal and a voltmeter.
You could also check the Source to Speaker voltage ratio of the Arcam at your preferred listening level.
regards Andrew T.
Old 19th August 2014, 04:08 PM   #4248
giuliodido is offline giuliodido  Italy
In a balanced DCB1 build using the following schematic:
will it be possible to accept unbalanced sources by shorting pins 1-3? Will it work?
Old 19th August 2014, 04:19 PM   #4249
Erlend Sæterdal is offline Erlend Sæterdal  Denmark
Default Sjøstrøm Buffer
Would it be ok to add this buffer after the Dcb 1 and on the same supply ?
http://sjostromaudio.com/pages/index...r#.U_N4csV_vnd
Old 19th August 2014, 04:29 PM   #4250
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
What, two buffers in a row? Typically it should work although not sure if to the better.
Salas hotrodded blue DCB1 buildHide this!Advertise here!
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 05:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 03:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 07:40 AM
