Salas hotrodded blue DCB1 build
Old 28th February 2014, 11:53 PM   #3831
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by Scorpion View Post
Hi everyone,
Here is a thread about some resistor tryouts in the Salas hotrodded DCB1...
Salas hotrodded DCB1 resistor tryouts
Let's have some fun and see what comes out of it ;-)
Scorpion
Wishing you it will stay just a "fun" thread.
Old 1st March 2014, 12:14 AM   #3832
Scorpion is offline Scorpion  Canada
Yep !!!
Can already imagine believers vs nonbelievers starting a guerilla over the difference in sound (or lack of) between different types and brands.
Measures and science vs what one's hears detect or how he feels (can it really be measured ?) while experimenting. Already expecting the "biased" stuff popping up...
I will post my findings no matter what. And some pics as well.
If there are audible differences, ok. If not, so be it.
Scorpion
Old 4th March 2014, 03:11 PM   #3833
nbivol is offline nbivol  Turkey
Hi Salas
Is there any problem if I use 100uf/16V instead of recommendet 100uF/25V ? Just have two of BG N out of buisness from another project.
Old 4th March 2014, 07:44 PM   #3834
Salas's Avatar
Not a problem. Its just 10V there across each of those caps.
Old 4th March 2014, 08:28 PM   #3835
Thank you
Old 14th March 2014, 09:22 PM   #3836
mrWagner is offline mrWagner  Hungary
I'm trying to figure out if my trafo is enough or not.
At the moment I have 16.5V after rectifiers. Regulated out is 10.4.
I measured 2.1V on the resistors (11 ohm) and about 3.8V on the IRF.
So I'm not really sure if this will be enought or I should get a bigger trafo? Or short circuit 1 LED and get about 8.5V reg out?
The absolute minimum is the regout+IRF+res voltages?
Old 14th March 2014, 09:28 PM   #3837
Salas's Avatar
5V difference DC in minus DC out is a safe minimum. More would be welcome but not an absolute must. Don't use 8.5V bcs l had found 10V more pleasing among many options during the original development.
Old 15th March 2014, 01:44 PM   #3838
5V?
But the IRF needs about 4V and also 2V drops on the resistor. That is 6V already. That is why I asked that I barely have any margin if error. 10.4 (out)+3.8 (IRF)+ 2.1V (resistor) is 16.3V. Are you sure about the 5V?
Old 15th March 2014, 02:58 PM   #3839
Salas's Avatar
No, its VGS is developing between DC raw and towards GND not between DC raw - DC out. That drop across is VDS. Its current is ICCS=(VRdrop=VFtot(LEDS)-VGS)/R.
Old 15th March 2014, 08:02 PM   #3840
Stixx is offline Stixx  Germany
Stixx's Avatar
That's a good one... Salas are you really sure ?
Salas hotrodded blue DCB1 buildHide this!Advertise here!
dcb1 buffer with shunt reg. merlin2069er Swap Meet 0 3rd August 2010 06:25 PM
F2 and DCB1 parts selection - please advice! DQ Pass Labs 6 25th November 2009 04:20 PM
Y B Blue - how blue LED improves the CD playback Peter Daniel Digital Source 176 25th September 2003 08:40 AM
